headlight motor bushings - need your ideas!
Engine: LB9 5.0L TPI
Axle/Gears: 9-bolt Borg Warner, 3.45
i am rebuilding myheadlight motor. the 3 plastic bushings are destroyed, i've heard people use rubber hose to act as a replacement...any idea how that will work? i thought of filling it with epoxy to strengthen it.
hawks third gen offers a rebuild kit but its $26, but I don't feel like giving it to them. i feel like there is something that you can use for free around the house but i just cant think of it...any ideas??
Car: 1988 Pontiac trans am
Re: headlight motor bushings - need your ideas!
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
hobby store, teflon plastic in all sort of shape n sizes, easily made into,,,,, a Qjet trick to use Teflon sheet to replace bushing over brass, it doens't wear out and wont bind.
Transmission: Pro-built 700R4
I just used three ball bearings from the local hardware store. Cost me a total of $0.75! That was back in '00 or '01 and it still works like a champ.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
If you don't want to use the proper bushings, at least use something soft. If you put in something solid, there is a possibility that you will break other parts if something goes wrong. Personally, I would prefer the bushings to be the sacrificial piece.
I used old scrap fuel line for the free fix.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I bought a few inches of 1/2 inch delrin dowel and cut the required pieces. Cost a buck and will make quite a few bushes.
last night i bought four sets of bushings off ebay for 15 including shipping. wish i knew they sold delrin dowels, i would have just went that route.
thanks for the help guys
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
NBrehm
Aug 5, 2015 07:57 PM
