Is this TBI setup going to work?
Old May 27, 2014 | 09:08 AM
MustangBeater20's Avatar
Car: 1991 Camaro RS
Engine: Built TBI 350
Axle/Gears: 3.42 Posi
I have a 350 with a LT4 hotcam, air gap intake, and vortec heads. Can I put a 454 tbi on without problems? Or am I going to have to chip it?
Old May 27, 2014 | 10:17 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Is this TBI setup going to work?
Oh, it is definitely going to need tuning. And it isn't going to work all that well with an air-gap intake. Wet flow TBI needs some heat in the intake.
RBob.
Old May 27, 2014 | 11:48 AM
Car: 1991 Camaro RS
RBob.
Is it going to need a chip? Or just a tune? I'm new to fuel injection...
Old May 27, 2014 | 12:15 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
A chip and a tune are basically the same thing, but a chip is a physical copy. Where as with tuning software you can get multiple tunes, which is what will be needed. Check out dynamicefi.com
Old May 27, 2014 | 12:20 PM
Car: 1991 Camaro RS
When I dyno it can they tune it?
Old May 27, 2014 | 01:44 PM
Car: 1991 Camaro RS
What did you do with your motor? I see you have a built TBI LO5. How did you tune yours?
Old May 27, 2014 | 02:48 PM
If you are going to a tuner who uses a dyno, yes. If your just going to a dyno to put your car on the machine, no.
I went with rbobs EBL Flash. It's not only an amazing piece of tuning software, but it's an outstanding diagnostic system. It gives full read outs of malfunction codes (SES Light) and gives very in-depth readings of ALL sensors. From voltage to steps, counts and lots more!!!! Check out that website or search EBL Flash.
Old Jun 5, 2014 | 01:09 PM
Car: 1991 Camaro RS
RBob.
What if it's my daily driver in the summer only? Can I still run an air gap? I'm highly considering getting your EBL flash.
Old Jun 5, 2014 | 04:00 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Even in the summer the temperature can vary greatly between early-morning and mid-afternoon. Can try it and see.
RBob.
MustangBeater20
Oct 29, 2022 09:20 PM
Terrell351
Jun 13, 2021 01:13 PM
pimp2303
Jul 27, 2017 02:03 PM
Street Lethal
Aug 13, 2015 08:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
