Anybody have experience with these heads?
Old Sep 10, 2014 | 09:21 PM
siguy2k's Avatar
Found these while searching around. Anyone have first hand experience?
http://pages.ebay.com/motors/link/?nav=item.view&id=311078661913&alt=web
Old Sep 10, 2014 | 10:15 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: Anybody have experience with these heads?
It's a Procomp head. And yes, they're absolute garbage. If it's cheap, there's a reason behind it when it comes to heads.
Old Sep 10, 2014 | 10:17 PM
siguy2k's Avatar
Care to elaborate? The design? Or the valve materials, spring, etc?
Old Sep 10, 2014 | 10:32 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Horrid casting design, thin seats, ports are usually way off, terrible hardware, guides can sometimes be messed up/off, castings can sometimes be uneven requiring milling, they're made in china.
By the time you fix any issues with those heads you'll have spent enough to purchase a good set of heads and you'll still have a heap of scrap. Definitely not worth it. Want a budget head? Get a set of refurbished Vortecs.
Old Sep 10, 2014 | 10:46 PM
siguy2k's Avatar
I'm wanting to build over 500 hp at the crank out of a 350 bored .40 while keeping the compression as low as possible. So definitely want to get a good flowing set of heads.
Old Sep 10, 2014 | 11:47 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Any other stipulations to the build? What is the budget? Some kind of forced induction would be the easiest way to reach 500hp while keeping the c.r. Lower. Whether n/a or using a power adder I would look into afr or brodix heads much better quality then procomp and they will reliably support your power goals.
Old Sep 11, 2014 | 08:26 AM
siguy2k's Avatar
Want to keep it n/a. Will eventually have some nitrous so going to be building for strength also. I'd like to keep budget down. I'll be doing all the work myself except for a few things like cam bearings and such. Want it on pump 91. I think it's attainable.
Old Sep 11, 2014 | 08:56 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
500hp, low compression and NA on a 350. I don't think that is going to happen any time soon.
If you do get it to happen you will need to spend big $$$ there will not be one stock parts in the engine and expect to spend over $1000 on heads alone. A solid roller cam will also set you back some decent $$$.
Old Sep 11, 2014 | 10:30 AM
siguy2k's Avatar
Well rods and pistons are going to be changed obviously. When I say low compression I'm talking 11 or less. And I don't see why or how it wouldn't be attainable with the right combination of off the shelf performance parts.
Old Sep 11, 2014 | 10:50 AM
Eric-86sc's Avatar
Engine: 305, 355
Of course your goal is obtainable it's just the cost factor that throws everyone off. I'm sure you have heard the saying about cheap, fast, reliable. An 11:1 small block with a forged rotating assembly a high end set of aluminum or race ported heads and an aggressive cam with over say .550 lift will reach your goals but don't expect to build it for around 2-3k
Old Sep 11, 2014 | 10:59 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Here is a combination that gets close......
355
10.7 comp.
AFR 195's
Comp 280XFI
1.6 rockers
TRW forged pistons two valve reliefs
Extremely welded and ported manifold that flows in excess of 340 CFM
Short intake runners
1 3/4" shorty headers
3" catback exhaust
495/500 flywheel HP/TQ
That's a budget build.....
That was not cheap to build.
Old Sep 11, 2014 | 01:33 PM
siguy2k's Avatar
Unless I'm missing something I don't see why it can't be built for that cheap?
Heads=$1000
Pistons=$140-240
Rods=$180-260
Cam and valvetrain=$6-800
Have everything else. And like I said I'd be doing the majority of the work myself.
siguy2k's Avatar
355
10.7 comp.
AFR 195's
Comp 280XFI
1.6 rockers
3" catback exhaust
Thanks for a real world reply. Question though. Why not use a higher flowing head?
Old Sep 11, 2014 | 01:50 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Higher flowing? Most people using small blocks will only dream of hitting a true 300 usable CFMs... let alone 340.
you're asking a real tall order. Throw nitrous on a build like that and it's going to blow up in your face.
Old Sep 11, 2014 | 02:11 PM
Dyno Don's Avatar
Heads=$1000
Pistons=$140-240
Rods=$180-260
Heads=$1500 now
Pistons=$390
Rods=$460
Timing set $120
Forged crank (for NOS) $800
Machine work $600
That's about $5-6K in my book. plus the manifold work (about $800)
If that's cheap for you "awesome"
Old Sep 11, 2014 | 04:00 PM
siguy2k's Avatar
Heads=$1500 now
Pistons=$390
Rods=$460
Timing set $120
Machine work $600
I guess I've found the parts cheaper Idk. Thanks.
Old Sep 11, 2014 | 04:28 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Cheap /= Good and Good /= Cheap
To make 500 HP NA will require something north of 6,500 RPM, probably more like 7,200-7,500 and that is going to take some very heavy duty/quality and therefore $$$ parts to keep it in one piece. 500 HP will also need a plethora of drivetrain and suspension modifications along with improvements in the braking and other safety features of your car.
Old Sep 11, 2014 | 04:39 PM
siguy2k's Avatar
Should have clarified. I've found the quality parts for cheaper.
gta90
Sep 15, 2015 04:00 PM
Magman
Sep 12, 2015 10:43 PM
509 camaro fan
Sep 6, 2015 10:43 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
