Air cleaner stud Vs 383
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
[IMG]
[/IMG]
That is what is left of what was my four inch long air cleaner stud. I did not have it held it place with Loctite or a double nut. I only had a pretty air cleaner nut on top of it and I thought, famous last words, nothing bad will happen. Well, engine vibrated the nut off and then vibrated the stud loose. I am sure it had been sitting on the secondaries for a little bit because this happened within a few miles of me giving enough throttle to open the secondaries.
Out of the blue the engine shut off. No noise or warning. Tried starting it and it started and sounded like severe knock and shut off after a second or two. After that the engine was "stuck." Soon as I opened the hood I knew what had transpired and I was proven right after removing the cylinder head.
[IMG]
[/IMG]
The pistons are forged so piston was still whole. As you can see it took some denting, luckily I was able to order a single of the exact piston.
[IMG]
[/IMG]
I also found part of the stud flattened and stuck in the intake valve. The intake and exhaust valves are bent. Yes they are AFR heads.
[IMG]
[/IMG]
Got out my porting supplies and with very minimal time and material removal the chamber looks pretty good and is definitely reusable. Unfortunately the cylinder wall was not reusable. The stud managed to put a hair line crack in the wall, so it now is off to the machine shop to have a liner installed. Engine had almost 2500 miles on it and I am doing all of this over again because I did not take precautions to ensure the stud would not go anywhere. If you read this, TAKE THIS AS YOUR WARNING!!
[/IMG]That is what is left of what was my four inch long air cleaner stud. I did not have it held it place with Loctite or a double nut. I only had a pretty air cleaner nut on top of it and I thought, famous last words, nothing bad will happen. Well, engine vibrated the nut off and then vibrated the stud loose. I am sure it had been sitting on the secondaries for a little bit because this happened within a few miles of me giving enough throttle to open the secondaries.
[IMG]
[/IMG]The pistons are forged so piston was still whole. As you can see it took some denting, luckily I was able to order a single of the exact piston.
[IMG]
[/IMG]I also found part of the stud flattened and stuck in the intake valve. The intake and exhaust valves are bent. Yes they are AFR heads.
[IMG]
[/IMG]Got out my porting supplies and with very minimal time and material removal the chamber looks pretty good and is definitely reusable. Unfortunately the cylinder wall was not reusable. The stud managed to put a hair line crack in the wall, so it now is off to the machine shop to have a liner installed. Engine had almost 2500 miles on it and I am doing all of this over again because I did not take precautions to ensure the stud would not go anywhere. If you read this, TAKE THIS AS YOUR WARNING!!
Car: 1991 Z28 Vert
Car: 1983 Z28
Engine: 385 Fastburn
Re: Air cleaner stud Vs 383
Wow! Definitely going to double check mine next time I pop the hood.
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Hate to hear of your loss. Seen it happen several times never good. Tell everyone you know use a lock nut. Seems to me that Air Cleaners and new Carbs should come with a lock nut.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
DAMN
When i get home I am installing a lock nut and loctite.
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
I just threw up my lunch.........
