1989 Firebird Formula 305 TPI idle issue
Old Jan 21, 2015 | 04:45 PM
shadaw009's Avatar
Car: Firebird Formula
Engine: 305 MFI
1989 Firebird Formula 305 TPI auto trans. After driving for a while when I come to a stop light or sign an sit my cat start to drop rpms from 700 to 500 sometime more than it will kick to 1000 and drop to 200 or less and die or kick back up to 1000. Also throws a lean exhaust code for a couple minutes then goes off and this happens randomly, I have replaced the TPS sensor, pcv valve, iac valve, fuel filter, spark plugs, O2 sensor, all 8 fuel injectors and I have cleaned my upper intake and throttle body and relearned the idle air control. Also checked for vacuum leaks but found none, I was told to check for vacuum leaks again, do head gaskets, or replace my crankshaft position sensor or distributor. Don't know what to do next please help!!
Old Jan 21, 2015 | 05:01 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 1989 Firebird Formula 305 TPI idle issue
How are you checking for vac. leaks??
Old Jan 22, 2015 | 07:45 AM
shadaw009's Avatar
Engine: 305 MFI
I have sprayed the hoses with carb cleaner, soap and water, and there is no noticeable hissing sound.
Old Jan 22, 2015 | 08:34 AM
mantaguy's Avatar
Engine: 5.0 EFI
Good Idea,i was going to suggest Starter Fluid.
Old Jan 24, 2015 | 08:24 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Could be egr related
Old Jan 24, 2015 | 10:27 PM
mantaguy's Avatar
Engine: 5.0 EFI
Is the "Service Engine" light coming on??if so what is the Code.
Old Jan 24, 2015 | 11:03 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Maybe check the fuel psi too.
Old Jan 25, 2015 | 08:37 AM
airblaine's Avatar
Car: 1985 Z28
Engine: TPI 400 SBC
my car did that many years ago, turned out it was the mass air flow sensor. once i replaced it the hunting went away.
on a side note, once your car is at idle disconnect the IAC then drive it to see if it still hunts. maybe it would help to see what component is causing the hunting, it is fuel delivery or air.
when you cleaned the throttle body dont forget to remove the IAC and clean the heck out of its cavity.
specialized
Jun 18, 2022 09:26 AM
Jae992
Aug 27, 2015 09:07 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
