1989 camaro wont start please help
I have a 1989 camaro that I just bought a spare key for...while in the parking lot I started the car with the original key with no problem I cut the car off and tried the new spare key and the car has yet to start...the original key will now not start the car either....there is gas in the car...and I tried disconnecting and re-connecting the battery..I am not sure what lights are currently being displayed because the gauges do not work...I think it may have something to do with the security light or computer.... Any thoughts or solutions?
Car: 88GTA
Engine: 5.7TPI
Re: 1989 camaro wont start please help
Car: 88GTA
Engine: 5.7TPI
"I just bought a spare key for" Where did you get that key? What is the resistance code?
Car: 88GTA
Engine: 5.7TPI
Here's some reading while you're waiting
Operation: Operation is fairly simple, but lets discuss what all makes up the PassKey system. The most obvious part is the key. The ignition key as a little "chip" in it. This is a resistor "pellet". There are 15 possible resistances, therefore 15 different types of keys each with a different resistance. This reduces the likelihood of a potential thief from having the correct resistance resistor on hand. Then you have to have a special lock cylinder to "read" the key. I use the term "read" loosely, because it does anything but read the key. I will explain more later. Next is the VATS module. It does most of the security work. It is the "brains" of the system. The module is what actually "reads" the resistance, but has to do it via the contacts in the lock cylinder and the related wiring. Think of the module as a Multimeter, and the wires and contacts the Multimeter Leads. The module reads the resistance and determines if the resistance is the correct value. The module will go into several modes, depending on what the module sees. There is "Tamper" "Normal" and "Fail Enable".
Normal: Normal is when the correct resistance is seen during cranking and the module will ground the Start enable relay, and send a "Fuel Enable" signal to the ECM. This basically "turns on" the injectors. If the Fuel Enable signal is lost or not sent, the injectors will never pulse. The signal is a unique "Pulse Width Modulated" signal, which is a series of rapidly switched "on" and "off" voltages. Once the relay is grounded, voltage is allowed to the "S" terminal of the starter, and the ECM is told to pulse the injectors and the car starts.
Tamper: This mode happens when the vehicle is cranked, and the resistance value as seen by the module is not the same as the value stored in the module. When this happens, the module shuts down for 4 minutes. Even if the correct resistance is then seen, the car will not start for the 4 minute "time-out". Each attempt to start the car within the 4 minute "lock out" period, will reset the timer. The security light will also illuminate for the 4 minutes. The Start Enable Relay will not energize and the Fuel Enable signal will not be sent. HINT: if the key pellet is dirty, it will put the module in the "Tamper" mode. If your car fails to crank/start and the security light comes on, try cleaning the pellet, wait 4 minutes, and try again.
Fail Enable: This mode is to help keep the motorist with the right key from being stranded. If a failure happens to the PassKey system AFTER a valid start, this mode is initiated. It allows the vehicle to be restarted, even with a failure present. The security light will remain illuminated to let you know a failure is present. However, this also means that the car can be started w/o a key, and is vulnerable to potential thieves. If battery power is lost while in fail enable mode, this mode will be lost and the next attempted start w/ the system malfunctioning will cause Tamper Mode.
Diagnosis:
If your car doesn't want to crank and the security light comes on, here are a few things that may hopefully get you back on the road:
First, make sure the pellet is clean. A dirty pellet will give a higher resistance than what the VATS module expects to see, and assumes it is the wrong key.
Check all of your fuses. If a fuse is blown or missing, it can cause a security problem.
Obtain a multimeter and measure the resistance of the key. Then remove the hush panel on the drives side of the dash and find the wires that go to the lock cylinder (usually two thin white wires, sometimes with orange insulation around both). Now measure the resistance at the two wires with the key in the ignition. If it doesn't come within a few Ohms of the original key resistance, the lock cylinder is bad.
If the resistance comes up OK, measure it again, this time while moving the key from "Off" to "crank" several times. Any fluctuation in resistance means a bad lock cylinder. This is the most common cause of failure. The wire are anchored to the stationary steering column, but attached to a rotating lock cylinder and over time, the wire breaks inside the insulation and usually becomes "open" in the crank position. This is read by the module as an incorrect resistance.
These are the basics of VATS diagnostics. If the problem is not found, it will have to be taken to a reputable repair facility.
Bypassing: I do not endorse bypassing the VATS system, therefore I will not go into great detail about it. Working at a dealership, I see tons of theft recoveries that never make it out of the parking lot thanks to the VATS system. It works.
Bypassing the system makes your car very vulnerable to potential thieves. Consider the cost of having the system fixed properly, to never seeing your car again, or in a ditch totalled. It happens. Bypassing involves finding the resistance of your key, and using a resistor in place if the lock cylinder, thereby fooling the module into thinking the correct key is in place, or bypassing the Start inhibit relay and disabling VATS in the EPROM.
Diagnosis:
Got it to work had to put the original key in the ignition and turned it to the on position in while the battery was disconnected....then reconnected the battery while the key was still in the on position...and cranked it up
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Glad you got it running. VATS is the EVIL being inside our (later year) cars. My 84 doesn't deal with it and I'm very glad it doesn't. What most people do, is have two spare set of keys made, and then they lock up their original key somewhere safe, just in case.
Or they do the VATS bypass procedure thich is outlined on the site here, just do a "search" for it.
Car: 1989 Formula Firebird
Engine: Swapped 350 TPI speed density
Axle/Gears: 2.73 (soon to be 3.42)
I understand the reasoning for not bypassing the VATS, however, I was not able to repair mine (young kid in high school). It had been hacked up by someone trying to put in a security system and there were parts that were now missing. I used a VATS bypass circuit BUT I wired a hidden rocker switch into the dash that could cut the power to the bypass circuit. That way, if I wanted to secure it, I could just flip the switch. Then, it acted just like the VATS was reading a bad key and wouldn't start.
I am only posting this as a suggestion for the many people who do use a bypass circuit. Better to have a little security than none at all.
If I had the money, I would have replaced the VATS system. Someday, I may go back and do that.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
