1983 Firebird Check engine light flashing
Old Feb 7, 2015 | 11:12 AM
Dave1983birdy's Avatar
Car: 1983 Pontiac Firebird
Engine: 305 v8
Transmission: automatic
Hi first time posting on here. I just bought this 1983 firebird the other day with a 305 v8 in it. Runs and drives amazing. However when im at a red light idling the check engine light comes on and stays there till i accelerate then goes away. She idles perfectly nothings shaking and i checked for vacuum leaks and found nothing. Just cant diagnose the problem as to why the engine light comes on and off light that. someone help please!
Old Feb 7, 2015 | 06:30 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 1983 Firebird Check engine light flashing
You need to check and see what code it's sending.
Old Feb 7, 2015 | 08:08 PM
Engine: 305 v8
How can i check what code it's sending when the check engine light won't stay on long enough for me to do that?
Old Feb 7, 2015 | 08:16 PM
mantaguy's Avatar
Engine: 5.0 EFI
It stores the info.
Old Feb 7, 2015 | 08:23 PM
mantaguy's Avatar
Engine: 5.0 EFI
there's a ECM terminal just right under the steering wheel.jump A&B Terminal and it will start a diagnosis of the codes your receiving
Old Feb 9, 2015 | 09:51 AM
Engine: 305 v8
Okay I need to go to a store and get it checked out cause I do not own the proper thing to check the codes. But does anyone have a general idea what it could be?
Old Feb 9, 2015 | 11:21 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
A paper clip can be used to jump the terminals, SES/CEL will blink out the codes. Jump the terminals first, then do a key-on, engine-off to blink the codes.
Do not start or crank the engine with A & B jumped on a carb'd car.
RBob.
Old Feb 9, 2015 | 01:23 PM
Engine: 305 v8
And how would
I know what the codes mean exactly. I do not have a manual for the car
Old Feb 9, 2015 | 02:19 PM
mantaguy's Avatar
Engine: 5.0 EFI
first when you jump the A,B terminals,your going to here the fans come on.The coding will start with 12 three times it will sound like this,ding---dingding, ding--dingding,ding--dingding that means the single ding is one(1) and the second dingding is 2, that means the code is Twelve(12) you will here the 12 3 times ,that means the ECM is starting a diagnostics of the car,then you will start receiving additional codes, example if you here dingdingding (short pause) dingdingding,that's code 33,you will here each code 3 times etc,etc,etc The diagnostics will be finished when you here ding--dingding that's 12 the test is over.After you get all your codes or code,come back here and list them,you will get plenty of help.
Old Feb 11, 2015 | 12:57 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
DO a search here on the boards, there are a few posts with a complete code list. 12 is the standard "I'm here, OBD circuit is functional" code. Means nothing is wrong.
Based on what you have said about it, I would suspect three things.
1. O2 sensor is shot.
2. NEed a new cat
3. Carb needs tuned.
It's most likely a rich/lean indication. I had an issue like it when I swapped in a 350 and wasn't tuned properly, the motor was running rich/lean at weird times. Went away mostly when I got it tuned. Only happens now when I let it idle for 10+ minutes. I call it a "soft" code because it's not stored passed starting the car. Meaning if the code comes on, to get the reading, you need to shut the car off, turn it to run and pull the code. The moment you start the car, the code is dumped from memory.
Old Feb 11, 2015 | 01:41 PM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
my friend that went to uti said if it is flashing, it is bad and do not drive it till you figure it out
Old Feb 11, 2015 | 01:50 PM
mantaguy's Avatar
Engine: 5.0 EFI
I wouldn't go as far as to not driving it!!it's probably something just miner,But I would have it looked at ASAP.
Old Feb 11, 2015 | 10:43 PM
Engine: 305 v8
Okay so I got it looked at and they said the codes 13 21 and 45 appeared. And that it is either the O2 sensor or the throttle position sensor. But most likely the O2 sensor. So ima replace that and see what happens its
Only 60 bucks
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
