need help or parting the car
Car: 88 Camaro
Transmission: T5/ Hurst shifter
Axle/Gears: 10 bolt/ 4000rpm 75mph 5thgear
hi i have an 88 iroc that has a surging idle when it warms up it also has a hesitation when reved or floored.. sometimes a random jerking on the highway like it is missing. i cant figure it out for anything.. ive researched for months and have found nothing. the car is a 305 tpi car with a t5. here is a list of parts i have tried:
coolant temp
o2 sensor
cap and rotor
plugs and wires
icm
pick up coil
radio frequency compactor
coil
swapped injectors with different ones
swapped computers
3 new maf sensors
maf relays
cleaned tb
upper intake gaskets
deleted egr and other emissions
no cat
any help would be appreciated i have a ton of work and money in this thing dont want to par it out
coolant temp
o2 sensor
cap and rotor
plugs and wires
icm
pick up coil
coil
swapped computers
3 new maf sensors
maf relays
cleaned tb
no cat
Car: 88 Camaro
Re: need help or parting the car
i did about a month ago before the surging problem ever started.. its always hesitated.. the last few time i let it run is when it started the surging. it will do it till it dies and if im driving and push the clutch in it dies also. i didnt do an extreme search for leaks though. i felt like i heard one then but could never find it and i ran out of brake cleaner.. i feel like its more than that.
well if you said you think there was a vacuum leak and never found it thats exactly where you should start. find that vacuum leak and any other vacuum leaks you may have. do it thoroughly so when you are done you know 100% sure there are no vacuum leaks then go from there
Car: 89 Iroc,
Engine: 5.7 TPI
Axle/Gears: 327
Always fix what you know is wrong first.Use carb cleaner or starting fluid for vacuum leaks,Just be careful.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
coolant temp
o2 sensor
cap and rotor
plugs and wires
icm
pick up coil
coil
swapped computers
3 new maf sensors
maf relays
cleaned tb
no cat
coolant temp
o2 sensor
cap and rotor
plugs and wires
icm
pick up coil
coil
swapped computers
3 new maf sensors
maf relays
cleaned tb
no cat
Car: 88 Camaro
i work at oreily auto parts so i get mad discount. i went through three mafs two a1 cardone and now a bwd 'borg warner' when i checked the tps it had a very small spot i didnt think was right but when i say small i mean small. i had it off the car so i was measuring resistance . it hit a point where instead of increasing it dropped buy about .02 ohms and then jumped to normal. this was in about a 3 degree rotation. also just checked the fuel pressure it was 42 at key turn never bled off. 33 to 34 at idle and wot it is 42 to 43. when it starts surging after 20 minutes of idling and warming up the pressure never changes once not even when its about to die. the fuel pump is new.. actually all the parts i listed have maybe 148 miles on them. the icm, distributor cap and coil have been swapped twice. is it a problem that it has an 86 style distributor and still has automatic prom? also timing is prefect i just set that when i did the pick up coil
Car: 88 Camaro
also its been about -5 degrees for awhile so i havent been checking the vacuum leaks if it has any. its been awhile since i drove my other camaro i cant remember if its normal when you have the heat on hot that it sounds like its sucking air really bad from the controls.
i was given a set of explorer injectors they are orange 19 pounders . do you guys know if they will work? i heard the for injectors are more reliable. only problem is when i compare the two the ford ones are a little shorter from oring to oring
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Question = Are you running the BWD now ?
Car: 88 Camaro
yupp running the BWD now. and these ford injectors are the skinny ones not the big fat ones. i used to get all kinds of maf codes.. swapped everything out and now i have no more codes and no more ideas. i think when i put the ford injectors in ill do the lower intake gaskets as well since ill be there and i get them for like five dollars.
Car: 86 IROC
Engine: 5.0 TPI
Car: 88 Camaro
ill have to see if i can get that one i had to special order the BWD and for some reason i got it cheaper than cardone. i was hoping i was done with mafs. at this point i wish it was a map car i have no problems with my other camaro. do you think the heater control sucking in air is normal?
Car: 86 IROC
Engine: 5.0 TPI
Car: 88 Camaro
so BWD offers a brand new maf should i try this or only run rich-porter. they both look way different than the one i have.. looks like it has a circuit board inside it. also i thinking about getting the 88 style distributor from rich- porter... i can get it for 66 bucks and warranty return all the stuff i bought for the other distributor so it will be even cheaper. i also got my new throttle body in the mail so i can swap tps sensors from my other camaro because i know it works. wish i was done with the maf on this car. i will never get another maf camaro lol its the most expensive maf i have seen.
Car: 86 IROC
Engine: 5.0 TPI
Car: 88 Camaro
i was gonna change the distributor because it is the old style with the coil on top when the car and computer should be running the separate coil distributor. and im not positive that its working correctly. i feel as though timing is getting cut or spark is not happening at times. and i can get the brand new rich porter one for pretty cheap and know that its not the problem.
also do you know if in fact the explorer injectors will work. again they are the skinny ones that i think are a eighth inch shorter from o ring to o ring or you could say the original is longer by the thickness of an o ring.
Car: 86 IROC
Engine: 5.0 TPI
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
