comp xe274 in a 305?
Old Apr 14, 2015 | 06:33 AM
dhonda200's Avatar
I just bought a dual exhaust for my 87 Monte carlo 305 with a edelbrock 600 holly intake/ headers and before I knew it I had the engine and cam out of it I had a free cam I was going to use but it looked worn so I ordered a xe274 cam and am just curious if anyone has ever tried it in a 305? What were your thoughts of it how did it run?
Old Apr 14, 2015 | 10:22 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: comp xe274 in a 305?
Too big for factory compression ratio.
Plus, you'd need some serious gearing and torque converter to get useable power out of it.
That's a flat tappet cam. Isn't your block roller?
Old Apr 14, 2015 | 10:27 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I run that cam in my 355, great cam but a bit much for a 305 and it will not be happy on lower compression. If yours is a 87 block get a roller cam.
Old Apr 14, 2015 | 11:08 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I agree XE274 is too much cam....You should consider stepping back to something like this. Advance it 4* to sit on a 104* ICL. 87 Monte should have 081 heads and a flat tappet cam stock. I have only seen a few 88s with roller cams.
http://m.summitracing.com/parts/isk-...make/chevrolet
Old Apr 14, 2015 | 12:07 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Too many different criteria have to be met to make that cam work, but if you do hit them, it will be a terrible daily, but it will be very, very quick.
Old Apr 14, 2015 | 02:49 PM
2005Impalla's Avatar
Car: 86 Z28 T-Top
Engine: Vortec 350
Axle/Gears: I think 3.73 open dif
Cam is on the large side. If you can I would get a stall converter in the 2,500-3,000 RPM range and some 3.73 gears to go with it. The cam will have a slightly higher power band in your 305 than it would have in a 350. I would look at getting some aftermarket 305 heads or having 1.94 intake/1.5 exhaust valves installed in your heads and having them milled if you plan on keeping that cam in the 305.
Old Apr 14, 2015 | 06:22 PM
dhonda200's Avatar
Thanks for the responses, For some more info I left out my car has 3.73 gears shift kit 1800 stall although im sure more would be better. 9.5 compression also not a roller block. Again just to update so u guys have more info. Planning trick flow 58cc heads in the future but I don't have the money rite now.
Old Apr 15, 2015 | 06:53 AM
86LG4Bird's Avatar
1800 stall is about stock. It won't like that 274 cam
Old Apr 16, 2015 | 12:57 AM
Car: 1992 Camaro RS
And honestly for that cam you probably want 4.10s. That cam in a 305 is borderline in terms of streetable. You'll need a lot of compression too.
Old Apr 16, 2015 | 09:12 AM
Car: 86 Z28 T-Top
Engine: Vortec 350
The stall is too low but every thing else will be fine. The trick flow heads would be awesome but your almost border line being able to get a rebuilt 350 with some 2.02 heads from a machine shop for just a little more cash.
beastin91rs
Oct 9, 2015 07:38 AM
angel2794
Sep 8, 2015 06:22 PM
mz92274
Aug 25, 2015 08:47 AM
theurge
Aug 21, 2015 12:46 PM
