Rarity of 1991-1992 Formulas
Old May 11, 2015 | 09:05 PM
77 TA man's Avatar
Car: 1977 Trans Am,
Engine: Built 1973 Pontiac 400
Transmission: TH350
Axle/Gears: Stock 3.23 Posi
Sorry if this is the wrong board for this, but how rare are the 1991-1992 Formulas? I read the forums Tech Info and it said 5K something Formulas produced in '91 and about 1,000(ish ) made in '92. The car in question is Blue, silver ground effects and has T-Tops. Unfourtantly , thats all i know except the car is really rough, '91-'92 Front end, Turbo Fin wheels and Powerbulge hood, faded silver formula badging and has been sitting in the same spot in town since 2012. Should i try to save it in a couple of months when i have some $ on hand? All comments appreciated !
Old May 11, 2015 | 11:13 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: Rarity of 1991-1992 Formulas
The history board would be a better place for this but yea the 91/92 formulas are uncommon. Not really rare as they did build a few thousand but they're not really seen everyday or anything. Pictures are worth a thousand words on this dilemma. Id say its worth restoring since its a late formula but the car could be a complete rot box and only a parts car.
Old May 12, 2015 | 01:02 AM
Night rider327's Avatar
Car: 1988 Camaro
I just let my 1991 formula L98 car go about 3 weeks ago for $3250. It was a nice car with minor damage (cracked windshield and bad body work done on driver fender). Great running car.
5,490 '91 formulas built.
1140 or so with the L98 350 engine (which mine had)
Old May 12, 2015 | 05:26 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
1992 Formula production was very low at 1,017. It was the performance model and everyone knew the higher performance 1993 LT1 was right around the corner.
Old May 12, 2015 | 04:22 PM
77 TA man's Avatar
Car: 1977 Trans Am,
Transmission: TH350
I dont have any pictures right now of it but its rough, it'll probably need both 1/4s and a passenger fender. I just drive by it everyonce and awhile and by Blue paint i mean i see blue where the car isnt covered by splotches of black, visibly (20ft away) peeling primer and paint, and the passenger side fender has rust holes in it. The T-tops make me think its even worse on the interior. I dont know,
I'll need it as a DD and what not if i buy it. I will try to snap a picture of it if i can next time i go by.
Old May 16, 2015 | 04:52 PM
TheExaminer's Avatar
Car: 92 Formula WS6, T-top
Engine: 5.7L T.P.I.
Axle/Gears: Limited slip, 3.23 10 bolt
Is it a 350? If it's an OE 350 with ttops, they only made about 200 of those in 92, I'm not sure how many in 91, probably not many. Mine is an original 92 with 350/ttop, and in all my nosing around, I've only come across 5-6 of them. I'm sure there are more than that out there, but probably nowhere near the original 200ish that were made. As far as I know there are NO 91-92 GTA ttop350's because of weight. If it has that package, somebody swapped it in, and it's not original. Formy's were a couple hundred pounds lighter, so the ttop/350 was available in 91-92. Also, an original Formula 91-92 ttop 350 was supposed to come with GTA lace wheels to save weight. If this car has the normal Formy wheels, it's probably a 305, or someone swapped the wheels. You couldn't get the ttop350 without crosslaces. But yeah, even if it's just a 305, it's worth saving. If it's a ttop350 and it's not eaten alive with rust, don't walk, RUN to the bank and get cash! If its a rust bucket, not so sure I'd go for it.
Old May 16, 2015 | 05:15 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
If it has ground FX, they were put on or it isn't a formula. Sounds like another hybrid.
Old May 16, 2015 | 05:21 PM
Engine: 5.7L T.P.I.
Oh yeah, didn't notice that when I first read the OP. And a sigh of disappointment issues up from the crowd as they walk away crestfallen..... Another phony Formy.... One cause for hope is that they are a different color than the car. Could be someone added them....
Linson
Oct 24, 2025 02:00 PM
okfoz
Oct 13, 2015 02:19 PM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
