Are plug wires for TPI 305s the same as TBI 305s?
Old Dec 18, 2001 | 05:45 PM
Brad91Rs's Avatar
Car: 1991 RS and 1998 Trans Am
Engine: 6.0L(lq4) & 5.7L(ls1)
Transmission: 4L60e
Axle/Gears: 323
I have a 305 TBI RS and i need new plug wires. I'm planning on switcing to TPI pretty soon, and I saw some accel wires for TPI cars in jegs for 53 dollars. I was wondering if these will work for my engine. Thanks
Brad
Old Dec 18, 2001 | 06:05 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Better wires will result in the most "spark" getting to the cylinder to "light" the mixture. I have heard people complain about Accel wires. I run MSD 8.5 Superconductor wires which only have 50 ohms/foot (stock GM is almost 1,500 ohms/foot). I have measured the resistance and compared them to other wires and definitely the MSD 8.5 Superconductors have the least amount of resistance of any plug wire.
As for durability, they last as long as any other good wires I have tried. After 2 years of running, 6 out of the 8 wires were still very close to their "resistance" that they were when brand new (could reuse). One was weak (should be replaced) and the other was very weak (needed to be replaced). That is about as much (two years) as I get with other quality plug wires, so I felt happy with the results.
BTW, I replaced all 8 even though only 2 really needed to be replaced. Better to do it once every two years than constantly tracing a "weak" plug wire every couple of months (had I just replaced the bad ones).
Old Dec 18, 2001 | 06:06 PM
FAKEIROC's Avatar
I Just Switched To TPI From TBI And Mine Worked Fine
Old Dec 18, 2001 | 06:42 PM
Car: Death Mobile
Engine: 666 c.i.
I hope you are not saying that you are running your TPI with the TBI ECM?
Old Dec 18, 2001 | 07:15 PM
FAKEIROC's Avatar
Should It Not Run! Just Kidding LOL.I Did Change The Wiring Harness.And By The Way Was Not Near As Bad As Converting To 5spd.
Old Dec 18, 2001 | 08:19 PM
Brad91Rs's Avatar
Transmission: 4L60e
Axle/Gears: 323
FakeIroc, how long did it take you to do the switch? Did you change fuel lines, and what type of fuel pump did you use? I'm probably going to start the swap this month, anything in particular i should know about it? Thanks,
Brad
Old Dec 18, 2001 | 09:16 PM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
Transmission: 6 spd.
Axle/Gears: Ford 9" 4.11
I have a solution, just buy the 350 plug wires, take out the tbi 305 and buy a 350, then stick on your tpi and throw the old engine in a ditch.
Old Dec 19, 2001 | 02:50 PM
FAKEIROC's Avatar
Brad91rs
Took Me About A Week A Couple Hours A Day.I Used The Same Fuel Lines That Came On The Car.Fuel Pump I Bought A New One For The TPI.Mine Was A MAS System If You Are Doing It To A 91 I Beleave Thay Were Speed Density.I Had A Compleate Doner Car So That Made Things Easyer.I Did Not Change The Interior Harness So I Will Need To Change Some Pins There But It Runs And Every Thing Seems To Work.Good Luck!!!!!!!!!
SmnitWS6TA
Not All Of Us Have $1000.00s Of Dollar's To Throw Away On Our Cars.Mine Is A Driver That I Like To Tinker On But Small Things Like Morgage Payment Property Taxes Utilitys And Truck Payments Keep Us From That.Don't Get Me Wrong I Would Love A 350.
1992 Trans Am
May 10, 2023 07:19 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
djmarch
Aug 9, 2015 05:27 PM
