Tools for dimmer switch
Old Aug 13, 2015 | 06:07 PM
Dkelz313's Avatar
Car: 1992 Camaro
Engine: 5.0
Just wondering what tools have ppl used to swap out the dimmer switch.? Everyone says it's a quick and easy fix, which is how it looked, but it is impossible for me to fit my socket wrench in there to get that first bolt. What tool's have you all used for this.?
Old Aug 13, 2015 | 06:43 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Re: Tools for dimmer switch
If you're referring to the remote dimmer switch on firebirds then it can be a pain in the ***, I believed I used a very short wrench to get in there and loosen the bolt, once it was loose I either used my fingers to take it out or I had a small ratchet.
All I remember from the job was that it was a real pain but well worth it to have dash lights again
Old Aug 13, 2015 | 07:05 PM
Dkelz313's Avatar
Car: 1992 Camaro
Engine: 5.0
Aren't they almost the same between camaros and Firebirds.? But I have a camaro. As I was trying, I figured if I did get that bolt off then I don't know how I'd maneuver the wrench or my fingers to even get the bolt back on.
Old Aug 13, 2015 | 07:14 PM
TylerSteez's Avatar
Engine: 383 stroker
Are you referring to this dimmer switch? If so I'm pretty sure they're only in firebirds but I could be wrong
Old Aug 13, 2015 | 07:26 PM
Dkelz313's Avatar
Car: 1992 Camaro
Engine: 5.0
Oh, yeah ours are longer and narrower than that
Old Aug 13, 2015 | 08:20 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Does this help?
https://www.thirdgen.org/forums/elec...placement.html
Old Aug 13, 2015 | 08:45 PM
Dkelz313's Avatar
Car: 1992 Camaro
Engine: 5.0
Originally Posted by Scorpner
Not really, I just need to figure out what tool to use. I think I could use a normal wrench but would need to know the size, and with a wrench I don't know how I'd get the bolts back on from that upside down angle.
Old Aug 14, 2015 | 12:21 AM
Night rider327's Avatar
Car: 1988 Camaro
Most of the little screws inside the car's cabin/cockpit are 7mm heads
If you are talking about the dimmer switch on the bottom of the steering column, just drop the column down and it makes it much easier.
Take any plastic panels off under the dash below the column, take the 2 bolts off that holds column up (13mm or 15mm head, can't remember, but think it's 13mm)
Column will lower down, then use a 1/4" drive ratchet and 7mm socket to remove the screws.
Heck I use a dewalt cordless 1/4" drive impact with a flex shaft and 7mm nut setter with magnet in the end of it.
Old Aug 14, 2015 | 12:45 AM
Dkelz313's Avatar
Car: 1992 Camaro
Engine: 5.0
Ok thanks, that helps. To get the column down do I have to remove the upper panel to do that, or can I do it from the bottom panel where the dimmer switch is.?
Old Aug 14, 2015 | 12:48 AM
Dkelz313's Avatar
Car: 1992 Camaro
Engine: 5.0
Or matter fact I seen you said take the panels off under dash, so that means both right.? And the screws would probably be under the upper panel.?
Old Aug 14, 2015 | 07:29 AM
Scorpner's Avatar
Engine: V6, V8
That was one of the suggestions in the link I posted, drop the column. But it also mentioned how to adjust it properly. Good luck.
Originally Posted by justcallmeclassy
It was actually a very simple fix, dropped the column, replaced the old switch and bam, it works like new. Only took about 15 minutes
Originally Posted by NINÅ
...The dimmer switch is located at the bottom of the column.
First make sure it needs replacement, and that it’s not merely out of adjustment.
You can adjust it by loosening the hardware, sliding it, tighten it then test with the stalk, then readjust as required...
Originally Posted by camaronewbie
...The actual switch may just need to be adjusted and not replaced, saving you even more money (assuming you still have your receipt). Two small screws hold it on, loosen them, and slide switch upwards just a tad, retighten, and check hi/low beams.
If you have tilt wheel, tilt the wheel down to normal driving position BEFORE adjusting switch - you want it to operate when you are driving, not when you are parked and the wheel is tilted up (and it's rare that you can adjust it for all tilt positions).
Old Aug 14, 2015 | 08:47 AM
Dkelz313's Avatar
Car: 1992 Camaro
Engine: 5.0
Oh ok , thanks. But it does need to be replaced it was adjusted years ago and I still haven't had high beams. So I'm going to try dropping the column today.
Old Aug 14, 2015 | 05:23 PM
Scorpner's Avatar
Engine: V6, V8
I see. I was wondering why you didn't mention the adjustment part. Dropping the column is pretty easy once you remove the panels. Yes, both panels need to be removed as the steering column will drop down to the seat. There are two bolts on either side of the column, 15mm IIRC. From what I recall, the steering wheel will rest on the seat if you have tilt and adjust it downward.
FWIW, I've found the heads on the 7mm screws to be on the shallow side so I ended up filing/grinding the open end one of my sockets down to get a better grip on them.
Old Aug 14, 2015 | 07:21 PM
Dkelz313's Avatar
Car: 1992 Camaro
Engine: 5.0
Alright thanks for the extra info, I was going to try it today but ran out of time, so I'm going to try knocking it out tomorrow morning. Sounds easy enough.
Old Aug 15, 2015 | 06:17 PM
Dkelz313's Avatar
Car: 1992 Camaro
Engine: 5.0
I swapped out the dimmer switch, but in doing so I must've pulled the rod out of place on accident. The rod that pushes into the dimmer switch when you flip the turn signal etc lever to switch between lo n high beams, does anyone know how I can get to that part of the lever to fix it.? I didn't see any screws or anything connecting the pieces around it.
Old Aug 16, 2015 | 11:42 AM
Scorpner's Avatar
Engine: V6, V8
I tried taking pics of a parts column I have but they were blurry and was missing the lever anyway. Below are links that should help better than what I came up with. IIRC, you might have to take it apart from the front if you can't get it hooked back up from the outside. Both threads linked below may show how to do this or you can also search via youtube for disassembly info.
From here:
http://www.camaroz28.com/forums/gene...-beams-726560/
Difficult angle but shows the rod attached to the dimmer and the shape at the end to go with the other pic above. I'm thinking if you can see what is inside you amy be able to manipulate it back in place.
From here:
http://www.fiero.nl/cgi-bin/fiero/sh...&thread=088020
It doesn't seem like there is much room for it to move around so there could be a problem inside anyway. Did you check the old dimmer switch my moving it manually by hand? (Ie. plug it back in and see if it works.)
Old Aug 16, 2015 | 03:07 PM
Dkelz313's Avatar
Car: 1992 Camaro
Engine: 5.0
From here:
From here:
Thanks those pics are perfect, I'll check the links in a second. And I think I messed it up by taking my hand and tugging/pushing/pulling the rod in and out of place by hand when I was trying to adjust the new switch, so I think I must've pulled it out of place.
Old Apr 7, 2016 | 10:38 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
That was a PITA to adjust. I dropped the column down as advised above, but getting to that rear bolt was not easy. Took me three hours to get it done. Oddly enough, my bolts were 8mm instead of the standard 7mm. Weird.
gta892000
Aug 11, 2019 11:16 AM
tglennon11
Sep 23, 2015 05:30 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
Randomtask2
Sep 10, 2015 08:37 AM
mrdevontay
Sep 2, 2015 08:04 PM
