Headlights aren't working why?
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
Well long time since I've been on but it's been that long of a time that I've haven't had problems with my car, anyways my headlights aren't working why? I already replaced my head light switch, new fusible links, cleaned up my head light connections also my ground for my lights, what exactly is going on?
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Headlights aren't working why?
are you getting power to the switch and out of the switch? dimmer switch on the top of the column working properly?
Car: '90 Camaro
Engine: 305 tbi
I'm getting ready to test my wires, but I assume it works because I can dim my gauges and also my tails come on too just no head lights..
Car: 86 Camaro
then i'd be looking at the dimmer switch, but also keep in mind that the power feed for the headlights comes off a different terminal on the switch than the dash or tail lights..
Car: '90 Camaro
Engine: 305 tbi
It was the dimmer switch, now I have to find out what ground wire has a weak connection.. Thanks for the help
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3:73
Car: '90 Camaro
Engine: 305 tbi
I do not know, I did however see a ground that's under the dash closer to the radio side, you could prob trace that back
Ghettobird52
Jul 5, 2024 11:18 PM
