Have spark, have fuel, won't start
Old Sep 10, 2015 | 08:18 PM
camarohelp's Avatar
I'm totally stumped.
86 trans am, 305, edelbrock performer carb.
I replaced the distributor rotor and cap, and now the car won't start. I've checked and rechecked the firing order, verified that I had spark, verified that the engine block is grounded, and I can't get the car to make a sound.
I tried spraying starting fluid into the carb throat, nothing, just cranks. No popping, no misfire, nothing. Fresh battery.
The distributor hold down screw is tight, so I don't think I rotated the distributor while it was off. But if I did, could I have screwed up the timing so badly that the car won't even missfire while it cranks?
Old Sep 10, 2015 | 08:25 PM
Vader's Avatar
Re: Have spark, have fuel, won't start
Does this still have the original style coil-in-cap?
Where/how is the spark being tested?
Old Sep 10, 2015 | 09:13 PM
camarohelp's Avatar
Yes it does. I verified spark by popping the plug wire off of the #2 plug, putting it onto a new spark plug, grounding the body of the plug, and cranking the engine. I was able to see a clear blue spark.
The car was running fine two days ago.
Old Sep 10, 2015 | 11:43 PM
camarohelp's Avatar
Just installed a new coil. Verified blue spark again, this time from a different distributor lead. Still nothing.
The butterfly valves in the carb are actuating. I noticed that the accelerator pump was visibly squirting fuel, I disconnected it for now just in case I was flooding the engine, will try again tomorrow.
I'll also try pouring gasoline down the carb inlet to make sure the needle isn't stuck open.
Am I going crazy?
Old Sep 11, 2015 | 09:58 AM
MM2Robinson's Avatar
Car: 89 Firebird Formula
Kind of off the wall... Is your catalytic converter plugged? You might not have anywhere for the exhaust to go which would keep it from starting...
I'm just spit-balling here, but maybe?
Old Sep 11, 2015 | 11:30 AM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Get it started? If you are getting fuel and spark it should at least sputter. Pull a plug and see what it looks like. If all wet, flooded and will not fire. Pull the distributor cap and make sure the rotor is pointing to no. 1 tower when engine is at top dead center mark on balancer. You changed the rotor and cap so be sure those pieces are properly seated and aligned. HTH, GL!
Old Sep 11, 2015 | 06:10 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Weird that it's not even attempting to sputter or pop, I doubt it's timing since a poorly timed motor will still backfire. Check the wires coming off the side of the distributor cap on the coil.
Old Sep 12, 2015 | 11:14 AM
Vader's Avatar
Are the plugs soaked with fuel? That will shunt any spark energy to ground before a spark can develop across the gap.
Old Sep 12, 2015 | 04:13 PM
camarohelp's Avatar
Cleaned the carb. Nothing obviously wrong with it, floats within spec. Replaced all spark plugs and wires. Nothing.
Old plugs were worn out, and fouled out, some smelled of fuel, others were dry.
Pulled the dip stick, oil doesn't have coolant in it, so it isn't a head gasket.
Gonna pull a valve cover tonight and check if the valves move when the engine spins. Maybe I had a coincidental timing chain failure.
Doubt it, I went around to the exhaust and smelled gas after cranking.
I'll try to find TDC tonight and see if things are lining up.
This one's a mystery.
Old Sep 12, 2015 | 05:11 PM
Reese-J's Avatar
Have the ignition module under the distributor rotor testes. If it went bad then the vehicle will not start. I have had this problem a few times.
Old Sep 12, 2015 | 05:22 PM
Reese-J's Avatar
I have had one that was bad and it would still spark but it caused the timing to be 45 degrees off (electricaly).
Old Sep 12, 2015 | 11:01 PM
camarohelp's Avatar
I rreeaaallly hope you're onto something. I pulled mine off a little while ago. Vatozone gave me the wrong replacement. I'll have to get a ride to have it tested tomorrow.
Old Sep 13, 2015 | 02:44 PM
camarohelp's Avatar
Replaced the ignition module. Still nothing. Just a very slight hint of a sputter.
Pickup coil tested at 800 ohms.
I think all that's left at this point is to replace the entire distributor and reset the timing.
Old Sep 18, 2015 | 09:58 PM
camarohelp's Avatar
If anyone was keeping track, after replacing the distributor, it turned out to indeed be the timing. Apparently I had it just wrong enough that the engine wouldn't even sputter.
Not sure how I screwed it up. Maybe the old distributor cap wasn't seated correctly? Maybe I put the wires back one position from where they should have been?
In any case, expensive mistake, but I'm glad to have a smoother running car after going through everything. Thanks for the help.
Old Sep 22, 2015 | 03:19 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Axle/Gears: 3.07
Glad you got it figured out!
92camaroJoe
Jul 29, 2023 07:57 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
