Horrible Clanking sound.
Old Dec 22, 2001 | 11:09 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
This sound shows up when braking lightly and it starts around 25 mph to about 10 mph, and then goes away. But the last time I drove it I slowed down, it started to make the noise, and now it will not go away. Also if you slam on the brakes, hard braking, it wont make the noise. Im thinking it needs a major overhaul on the brakes, which only makes sense. Also, the noise comes from the rear.
I think Ill put the car on blocks tomorrow and see where exactly where the noise is coming from.
Any info or suggestions where to look would be great.
Old Dec 23, 2001 | 02:54 AM
lancer5067's Avatar
whassup in Paris!
Do you retain power brakes?? Is the sound coming from eng compartment or wheels/ Front or Rear. Does it pull either side?Could be as simple as low brake fluid to worn/ faded pads or even a messed up booster. You lose power assist at idle, but you can be moving 10 mph and idle simultaneously. Put it in 1st gear and try that 25 to 10 bit again. If it stops making noise at maybe 5 mph or so check all vacuum lines going to the booster and go from there. Good Luck!
Old Dec 23, 2001 | 07:05 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Sup in Abilene?
Well the fluid level is correct. Im positive the noise is coming from the rear of the car. Im pretty sure I have pwr. brakes still, can you tell this way?, when you press the brake the idle goes up a little bit right. So, also there is no pulling or any kind of shimmy or anything like that.
The sound is awful, kinda like banging two frying pans together, if you know what I mean. I was wondering if it could be a U-Joint cracked up or something. Just need to get under the darn thing, it wont fix itself, but the car took a back seat to football and beer today, so I'm just a lazy **** I guess.
Old Dec 23, 2001 | 11:41 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
my car had a similar noise on my 72. My wheel clyinder or something like that was bad. It was nasty looking. Its after you take off a front wheel and the little cap in the center. It cost me a whole $20
Old Dec 24, 2001 | 12:09 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Discs or drums?
Old Dec 24, 2001 | 11:54 AM
Camrs89's Avatar
Good ol drums!
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
xxx3man`
Sep 23, 2015 10:37 PM
camarohelp
Sep 22, 2015 03:19 PM
Stryker412
Sep 20, 2015 06:59 PM
cstrobel65
Sep 16, 2015 11:54 AM
