Bolt/Nuts 91 F-body Metric or US?
He guys
What type of nuts / bolts are used on a F-body '91. Metric or US? Specially under the hood, i.e. The bolt an the throttle body?
I've been using Metric wrenches so far so good, this afternoon I rounded a bolt (gas spring trunk) and before things get any worse, i was wondering who can help me with my question?
Don
Don
Re: Bolt/Nuts 91 F-body Metric or US?
Body hardware is virtually 100% metric. I would say 100% but there might be ONE somewhere that isn't that I haven't run across yet.
Bolts that go into castings (block, heads, intake) are SAE in V8 cars. Most accessory hardware is still SAE. No clue what they are in the 6-cyl ones. Hardware for electric, fuel, emissions type stuff under the hood is a mix but mostly metric.
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
I think the V6 head bolts are SAE, and the mains, and the rods, but all the rest is sure to be metric. Rear axles are a mix, T-10s were SAE, T5s and autos are metric
Or in general, it's smart to have a SAE by my side just in case?
Thanks!
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
You should always have a good set of SAE and Metric sockets/wrenches/etc. I've found a mix of both on my Formy.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
seems basicly most parts designed 1976 and later are metric threads and bodies from 1978 up are mostly metric-I had a '77 blazer and it was all SAE,but 1978 blazer had metric body bolts.One exception though is the crossfire injection system-all the larger bolts are SAE and that was designed in 1981
Car: 1988 Camaro
Mostly metric wrench sizes.
I just pulled a 3.1 v6 mostly apart and I can't remember any SAE sizes on the outside of engine unless you count the pipe fitting. Mostly 7mm, 10mm, 11mm, 12mm, 13mm, 15mm
Car: 1988 Camaro
Engine: 2.8 to 383
Its always been a mess for me. I ALWAYS grab the metric equivalent of anything i take to the car to work with. EX. If I think it's a 9/16, I grab a 14 & 15 too. Likewise for 1/2 and a 12 & 13.
