NEW TANK/SENDING UNIT/PUMP
Old Jun 29, 2016 | 04:22 PM
80's Al's Avatar
Car: 89' RS TPI,04' HEMI Dodge Q-cab
Engine: 383ci
Transmission: TCI 700R4, 3400 stall
Axle/Gears: 12 bolt 3.73
THINKING ABOUT GETTING THIS:
http://www.rockauto.com/en/moreinfo....5717&jsn=10474
WILL THIS PUMP BE GOOD FOR MY TPI SET UP? I KNOW IT HAS TO BE HIGH PRESSURE, AND NOT HIGH VOLUME.
DescriptionElectric Fuel Pump; 94 - 116 PSI; 52.6 - 61.9 GPH
Type12 vDC Turbine
Fuel TypeGas
Inlet TypeStrainer
InletN/A
Outlet TypeFor Hose
Outlet5/16
GasketsIncluded
StrainersNot Included
Old Jun 30, 2016 | 06:32 AM
80's Al's Avatar
Engine: 383ci
Re: NEW TANK/SENDING UNIT/PUMP
OK...little more info for you guys.
Running an Edelbrock HI-FLO TPI
BBK 52mm throttle body
Lucas 24lb injectors
What would be the recommended fuel pump PSI/GPH i should run with this setup?
Old Jun 30, 2016 | 01:14 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
I like the EP381, personally. I think it'd fit your build. I dislike Spectra brand components as they're pretty craptastic overall. Lowest bidder China stuff. Fine for daily driver cars but when you're pushing performance I hate sticking them on.
EP381 is 50-60gph @ 65-75psi.
http://www.rockauto.com/en/parts/acd...fuel+pump,6256
Note: It's quiet! I had a Walbro 255 before and it was stupidly loud.
Old Aug 16, 2016 | 06:42 AM
80's Al's Avatar
Engine: 383ci
ok, THTANNER, I took your advice...I ordered the full kit AND ordered the EP381 to go with it. Worst case, I have the Spectra fuel pump as a back up!!
should be here by the weekend!!
Old Aug 26, 2016 | 08:00 AM
80's Al's Avatar
Engine: 383ci
OK....THAT was fun
I knew pulling the tank was gonna be a PIA!
so....got it out....but i will prob have to drop the rear end even more to put the new one in.
the gas....well....smelled like paint thinner, literally. Testors.....took me back to the days of my youth building 1:24 scale model cars...
Old Aug 26, 2016 | 11:31 AM
thtanner's Avatar
Originally Posted by 80's Al
OK....THAT was fun
It's a fun process! While it is out, check the filler neck for cracks or leaks. They're know for it, even aftermarket tanks. Replaced my Spectra tanks recently due to a leak there.
Old Aug 26, 2016 | 12:56 PM
80's Al's Avatar
Engine: 383ci
Got it....will check it out....
also, notice my gas cap does not fit the new tank?
Old Aug 26, 2016 | 01:23 PM
thtanner's Avatar
With aftermarket tanks you need to use the included cap, or one from a second generation camaro/firebird.
Check the angle of the filler neck prior to assembly. Had to have mine cut and welded...
ars2pd
Apr 12, 2016 01:33 PM
mthibode
Apr 12, 2016 07:04 AM
aljohnsonii
Apr 8, 2016 04:21 PM
nuggie
Apr 3, 2016 08:58 PM
jimw67
Apr 2, 2016 01:06 AM
