replacing rocker arms and pushrods.
Car: 1987 GTA
Engine: 350 TPI w/ extras !
Hi guys,
My car has been making a tick tick tick noise for a while now and its annoying more than anything else. I thought it was my Bosch 3 injectors at first but its too loud, you can clearly hear it with the hood closed over the noise of the engine and it goes in time with the revs, so gets faster if you rev it, and it clearly sounds like its coming from the valve cover area.
Do you think it would be wise to pull the valve covers off and check they are all tight first before ordering new ones ? ive checked them years ago and all was well but the noise remained.
Ive never replaced the pushrods and rocker arms before so im not sure if its just a case of unbolting the arms and pulling the rods out and then replacing them, or is it more involved than that ?
Car: 91 G92 Z28
Axle/Gears: 342
Re: replacing rocker arms and pushrods.
Hi guys,
Car: 1987 GTA
that sounds terrifying adjusting while its running and they are going up and down ?? lol
Car: 1987 GTA
I will check them first but i dont think it is that. Someone said it might be a failed hydraulic lifter which would suck because id have to take the intake off and ruin the paint job on the top half of the engine.
Ive recently just done a 300 mile round trip to a show and back, sitting on the motorway for nearly 3 hours doing between 60 and 70 and the car runs great though, feels like it would just blast all the way upto 150 if i wanted !
Car: 91 G92 Z28
Axle/Gears: 342
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
It doesn't have to be messy and smoky at least for perimeter bolt heads.
I have a valve cover I use that is cut out right where the rocker nuts are and it keeps the splashing to a minimum. Trying to adjust valves while the engine is hot with the valve covers off IS a nightmare with hot oil flying everywhere.
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
it takes less then 1 minute per head to adjust while motor is running, also... check the rocker arm stud. Mine pulled up about 1/8 inch out of head.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A ticking sound under the valve covers is rarely a rocker/pushrod problem. It's always a good idea to replace the stock stamped steel OEM rockers with something better. A full roller of any type is nice. Even just installing a less expensive roller tip rocker is an improvement.
Pushrods don't wear out unless there hasn't been enough lubrication for the ends or it got bent from other engine damage.
There's always a possibility that a rocker nut has backed itself off slightly to cause the rocker to loose it's lash setting. Simplest thing to try first is to just replace all the rocker nuts and reset the lash.
More commonly, a ticking rocker normally means you have a cam lobe/lifter failure. As the lobe and lifter wear out, the amount of cam lift decreases and the lifter preload decreases enough that the rockers start making noise. Using a dial gauge on the pushrod tip while baring the engine over by hand can see how much lift is on the lobe. You would need to check all of them unless you happen to find one that's really bad first.
Valves wearing down into the seats will cause the valve stem to move higher and tighten the lash which won't cause a ticking. A bent valve won't sit on the seat properly and will increase lash causing a ticking sound but you'll also have other issues.
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
All this being said, my Bosch III injectors are the loudest thing on this planet.
Even with brand new hood insulation you can hear them over everything, very clearly.
I'm going to replace them eventually for that reason alone. They're obnoxious.
Abubaca
Mar 19, 2016 02:29 AM
