Torque Settings
Old Dec 27, 2001 | 12:40 PM
chevelless502's Avatar
Torque Settings
Does anyone know the rod and main bolt torque settings for a 1988 TPI 350. Thanks for any help you can give me.
Andy
Old Dec 27, 2001 | 03:14 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
i thought all two bolts are 65 ft/lbs
but the book for my 89 says mains 77 rods ft/lbs, rods 44.
Old Dec 27, 2001 | 03:15 PM
SoCo80p's Avatar
dont forget if your using ARP or other aftermarket rod or main bolts the torque specs will be diffrent, follow what the instructions say if you have aftermarket bolts
Old Dec 27, 2001 | 04:04 PM
ede's Avatar
ede
you ought to buy a manual instead of relying on second hand information here for something like this.
Old Dec 27, 2001 | 09:02 PM
I suppose you are right "ede" but if this sight is anything like www.chevelles.com sight that I normaly go to, the guys there are always out to help a guy rather than lead him in the wrong direction and give him false info or help. Thanks again for the help guys.
Andy
Old Dec 27, 2001 | 10:54 PM
82z's Avatar
82z
I don't know how picky you are but myself I would rather refrence stretch rather than torque for those all important bolts. Torque is only an inference of stretch based on the characteristics of the fastener and a thread lube. good luck
Old Dec 28, 2001 | 04:00 PM
ede's Avatar
ede
true the members here will and do go out of their way to help, but mistakes can and are made and there are always a few trolls that tell the wrong info to see what trouble they can cause.
Old Dec 29, 2001 | 07:55 AM
KeithO's Avatar
My Chilton's Repair Manual states the following for an 88 350 TPI:
Rod: 45 ft-lbs
Main bearing:
Inner: 70-85 ft-lbs
Outer: 60-75 ft-lbs
As stated above, if you have aftermarket equipment in these areas, you will need to adjust these values.
Good luck.
InfinityShade
Aug 22, 2015 08:00 PM
mustangdmurder
Aug 21, 2015 07:17 PM
Dialed_In
Aug 20, 2015 01:45 PM
gwade12
Aug 8, 2015 08:17 AM
