Does this sound like a carb tune problem or a trans problem?
Old 10-29-2016, 03:15 PM
mdtoren's Avatar
Car: 1986 Iroc Z28
So, been driving my 86 Iroc after finishing up my Carb swap and I am having the following issue and need some thoughts on where to start digging. Car is a 305, originally TPI swapped to carb and has edel performer manifold and holley street avenger 570cfm, Comp Cam 260h cam, 700R4 trans.
I am having a pretty decent stumble / miss fire just off idle during acceleration. Ive noticed it gets worse the longer I sit, a simple stop sign is less of an issue, a longer stop light creates more of a stumble. It appears that if I give it more gas it corrects the stumble and while cruising there is not a miss/stumble. Ive also noticed that at longer lights while idling Ill start to get a miss fire in the exhaust at idle. Car never dies and no stumble when rev'd in park/nuetral.
Im leaning towards carb tune issue because I never tuned the carb during the swap bc it ran, but, Ive been reading up on Torque converter issues causing spark knock, and I am leaking some trans fluid when the car sits for longer than overnight which went on long before I carb swapped.
Old 10-30-2016, 01:32 PM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Re: Does this sound like a carb tune problem or a trans problem?
It sounds like the carb is loading up at idle, in gear. Try doing an idle drop adjustment with a vacuum gauge and double checking the initial timing to make sure it's not too far retarded.
Old 10-30-2016, 01:36 PM
mdtoren's Avatar
Car: 1986 Iroc Z28
https://www.youtube.com/watch?v=UPGLUsW5ZeE
I will try this, Thank you!!!!!
Old 10-30-2016, 06:49 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
i had a vacuum leak that pulled this crap on me a year or so ago.
Old 10-30-2016, 07:13 PM
Car: 1986 IROC Z28
If that all checks good, check to make sure you are not running too much fuel pressure to that carb.
Old 10-30-2016, 07:16 PM
1987L69's Avatar
Car: 1984 Z28
Engine: LG4 305/4bbl for now
Transmission: 5-Speed
Axle/Gears: 3.23 Posi
did you switch your distributor with a non computer controlled one? if not that could be your issue
Old 10-30-2016, 08:00 PM
mdtoren's Avatar
Car: 1986 Iroc Z28
Yes, running a non computer distributor, I thought it might possibly be a spark issue, but have ruled that out.
Old 10-30-2016, 08:01 PM
mdtoren's Avatar
Car: 1986 Iroc Z28
Right now I am running 6psi from the regulator to the carb, does that sound too high?
Old 10-30-2016, 08:02 PM
1987L69's Avatar
Car: 1984 Z28
no, that sounds perfect for carbs, is that at idle or WOT?
Old 10-30-2016, 08:33 PM
zed-028's Avatar
checked the pcv valve lately?
recently had the stumble scenario at the lights, ordered a new one and pulled the old one to compare, completely screwed. might not be a bad test for $5
Old 10-30-2016, 10:06 PM
mdtoren's Avatar
Car: 1986 Iroc Z28
Idle, havent checked WOT.
Old 10-30-2016, 10:11 PM
mdtoren's Avatar
Car: 1986 Iroc Z28
Im not currently running PCV, just running 2 breathers instead. Any chance a PCV set up would fix this? I was under the impression either set up would work, but the PCV was just "cleaner"
Old 10-30-2016, 10:59 PM
zed-028's Avatar
nah probably not, the valves going out do all sorts of wierd stuff.
Old 10-31-2016, 08:29 AM
Car: 1986 IROC Z28
4 to 6 psi should be fine.
Old 10-31-2016, 01:58 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Check your ignition control module (ICM) inside the distributor cap. Whenever mine is going out (these cars eat them like candy) I get the symptoms you describe.
