Vortec Heads and LS6 valve springs - whos done it.
Old Dec 14, 2016 | 02:53 PM
86CamaroDan's Avatar
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
So ive been looking into blower cams and the stock vortec valves max out at 470" of lift because of the seat - Im looking to see whos running comp 787 retainers and LS6 valve springs - Also what kind of cam's are you running?
Was thinking about running a .503/.520 lift cam, but according to my math that puts me in spring bind territory.
Old Dec 14, 2016 | 03:20 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Vortec Heads and LS6 valve springs - whos done it.
Have you looked at the Vsk4h53
http://www.alexsparts.com/valve-spri...seat-pressure/
Where these the springs you were looking at ?
https://m.summitracing.com/parts/nal-12499224
Old Dec 14, 2016 | 04:01 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
combo with an LT4 hot cam here but 1.5 rockers
Old Dec 14, 2016 | 04:52 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
ls6 springs wouldnt fit over my few sets of vortecs without trimming down the boss
Old Dec 14, 2016 | 05:43 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Yep. But its been a few years. I wrote it all here. https://www.thirdgen.org/forums/tech...ortec-lt4.html
Might not be the best answer by now, but its still working good for me.
Old Dec 14, 2016 | 06:05 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I have run them on several sets and not run into that issue.
Old Dec 14, 2016 | 06:53 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
LT4HOTcam, 1.5 rockers... Same as NAF, and I'm sure I used 3rdgenmaro's thread as a guide...
https://www.thirdgen.org/forums/memb...ml#post5971619
Old Dec 14, 2016 | 06:58 PM
Car: 86' IROC
Axle/Gears: 3.45
Alex's doesnt have those kits anymore. I called them the other day - They want 175 for the current behive kit they have, plus seals, and retainers, and yes those were the springs i were looking at. Also if my math is correct, at 1.700"-.520 lift puts me at 1.18" and thats before retainer to seal clearance and spring bind is at 1.220
I had my eye on the LT4 hot cam, but im running a GM 350 HO (Flat tappet cam) and a little extra duration/exhaust lift could do me good with the blower - every thing i want except the added exhaust duration/lift
Trying to keep my power band lower, but everything lower 2-5800 range is down around the .480 lift, area and im running a .435/.460 cam already so its kind of pointless in my opinion to spend 5-600 hundred bucks for .020" more lift, so im thinking retrofit roller is in my future.Selection seems limited on the retro fit rollers for blower cars looking in the .490-515 range.
I was looking at this kid, dispite it being slightly higher power band than im looking for. My only question is, is it a huge pain in the *** down low to drive.
Im looking for a good drivability blower cam with decent lift (and a winning lottery ticket while im at it) - Starting to think i should have comp custom grind me a duplicate of the LT4 hot cam and add some duration? Im in quite the pickle. Looks like im spending 1100-1300 for a cam swap.
Any advice is greatly appreciated
Old Dec 14, 2016 | 11:30 PM
Engine: Lb9
Transmission: M20
Not sure if these would be of interest. Looks like they would fit your build maybe not as good as beehive.
https://www.thirdgen.org/forums/engi...n-pbm-sbc.html
Old Dec 15, 2016 | 06:36 AM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
thats what i thought, but both sets ive done it on ive had to shave them down, i bought the tool from Alex parts so i had it but still.
Old Dec 15, 2016 | 06:37 AM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
I also have an lt4 hot cam if anyones interested
Old Dec 15, 2016 | 04:57 PM
irocman7's Avatar
Car: 89' Sunset Metallic Orange Iroc-Z
Engine: Forged 383
Transmission: TR6060
Axle/Gears: 4.11 9 inch
I'm not running factory ls6 but running comp beehives on my vortec heads. Running the Comp 280xfi with 1.5 rockers which is about .550 lift with no problems.
Old Dec 16, 2016 | 10:41 AM
Car: 86' IROC
Axle/Gears: 3.45
Well, thats alot more lift than i thought they could even handle. Did you machine the seats or just springs, retainers and seals.
Old Dec 16, 2016 | 11:08 AM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
the guy i work with that is also on here runs .550 lift with press in and runs it at the track every weekend for the last 3 years
Old Dec 16, 2016 | 11:23 AM
irocman7's Avatar
Engine: Forged 383
Nope just had them tapped for screw in studs. That's why its a good option, you dont have to cut the valve guides. I used the comp retainers and put some new seals.
http://www.hotrod.com/articles/vorte...g-upgrade/amp/
Old Dec 22, 2016 | 04:09 PM
Car: 86' IROC
Axle/Gears: 3.45
What did you guys end up using for seals? Stock vortec's?
Old Dec 22, 2016 | 06:02 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Stock Vortec seals are an odd diameter. My machinist has a "standard" sized cutter to work with typical sized aftermarket seals... Comp 529 seals.
Old Dec 28, 2016 | 06:04 AM
3rdgenmaro's Avatar
Car: 88 IROC
Yes, stock vortec. Fel-Pro SS72861
http://www.rockauto.com/en/parts/fel...stem+seal,5800
Old Dec 28, 2016 | 12:39 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
i got mine from alex parts
Old Jan 2, 2017 | 05:00 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
I used a set of LS3 springs that were given to me, Comp 787 retainers and Felpro seals for Vortec. Running an LT4 Hot Cam on 1.5 rockers.
