speedo is off when speed is over 50 mph or higher
Old Jan 4, 2018 | 08:29 PM
greasegrenade's Avatar
Car: 89 Iroc,
Engine: 5.7 TPI
Axle/Gears: 327
1989 Iroc .Speedo is accurate up to 50 mph.After that it really speeds up.Like at 70mph gauge shows 90 mph.Any Ideas?
Old Jan 5, 2018 | 08:21 AM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Re: speedo is off when speed is over 50 mph or higher
Your cable is slipping, needs lube or better yet...don't drive it in the winter.
Old Jan 5, 2018 | 10:03 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Wouldn’t slipping cause a lower reading ?
Binding may cause higher reading but a fluxing gauge.
Just a thought.
Old Jan 5, 2018 | 01:00 PM
Car: 89 Iroc,
Engine: 5.7 TPI
Axle/Gears: 327
It has been an issue since i got the car.I got the trans gears dialed in hoping that was the problem,but no.It is dead on until 50 ish.My gut tells me there is a problem with the speedo head.I will pull the cable,clean and lube it next.
Old Jan 6, 2018 | 04:47 AM
Car: 88 IROC-Z
No, his cable is slipping and getting caught up (1 after the other...). I went threw this myself WAY back in the day. Guy needs to get a econobox daily driver. His pinch welds and front left corner floor metal aren't going to last long...
Old Jan 6, 2018 | 06:59 PM
Car: 89 Iroc,
Engine: 5.7 TPI
Axle/Gears: 327
I have had a drill turning the cable .Seems fine.I will pull the cable out of the housing and check and lube it. Its not a daily driver,I drive my old TPI 67 gmc pickup everyday.Iroc is for nice and dry days.
Old Jan 7, 2018 | 07:50 PM
NoEmissions84TA's Avatar
Do you have headers? I have read that with headers, the cable gets melted where it comes really close to the pipes. Check for that and you might need to add some heat shielding.
Old Jan 8, 2018 | 08:19 PM
Car: 89 Iroc,
Engine: 5.7 TPI
Axle/Gears: 327
Good idea, I have a set of shorties ,I will check
Old Jan 13, 2018 | 09:31 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
wrong speedo gears in transmission or they changed gears in rearend and you'll need to change speedo gears gears to match the rear end
cubby-5056
Oct 21, 2012 11:13 PM
gusman
Feb 4, 2003 12:26 PM
Ray87Z
Jul 15, 2001 12:16 AM
Ray87Z
Jul 14, 2001 11:45 PM
