Thread broken in Tilt Steering Pivot Pin
Old Mar 12, 2018 | 09:06 PM
Termn8r's Avatar
Car: 1989 Iroc Z28 Convertible
Engine: V8 5.0 305 TBI
I went to take apart my steering wheel column to tighten it up and got down to the pivot pins and apparently someone else had tried to do this and the left pivot pin had a screw broken off flush inside. I was able to easily remove the right one.
Being that pivot pins are made out of exceptionally strong material, I am unsure how "easy" it will be to self tap and heliocoil it.
Any suggestions, short of the above or maybe welding it and prying it out? I purchased 2 new OEM pivot pins in case I destroy this one.
Thanks!
Old Mar 12, 2018 | 10:26 PM
Drew's Avatar
Re: Thread broken in Tilt Steering Pivot Pin
Get all the tension off of it, ie remove the tilt spring if you haven't already. Then usually you can practically pull them out by hand, especially if they're well worn. I can't remember the last time I needed the tool to get em out. Try running the tilt up and down and look for the place where the pin seems loose. A strong rare earth magnet might be enough pull to get it out. Could use a stud welder to tack a pin to it, and pull it with a slide hammer. Or drill a hole, run a self tapping bolt into it, and use the bolt to pull it.
Old Mar 13, 2018 | 12:52 AM
Termn8r's Avatar
Thanks, the right pin was really tight, took pulling it all the way with the pivot pin to get it out. I will try again tomorrow if I have time and see if wiggling it around. Will definitely try a strong magnet.
Old Mar 13, 2018 | 08:05 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Can you get behind it? I haven't taken a column apart in a log time, so I can't remember. But if there is access, maybe you can use a long drift or a punch to knock it out from the back side.
Old Mar 20, 2018 | 08:13 PM
JA411's Avatar
If I remember right the pin is soft metal, drilling out the broken bolt would be a tougher metal to drill. The pins usually have a slight press fit, that's why there's a puller tool to remove. I would die ground or drill the center of the bolt enough to center a bit and drill till the the pin is thin enough to get out.
JOE
Old Mar 23, 2018 | 08:55 AM
rgauder's Avatar
Car: 1987 Trans Am
Same thing happened to me. Couldn't drill out the broken bolt because it was too hard. Welded a washer to the pin and popped it out.
Old Dec 29, 2021 | 12:25 PM
pat456's Avatar
Thanks!
I would drill into the bolt stuck into the pivot pin and use an extractor, the bolt shouldn’t be too tight , if that doesn’t do it then drill into the bolt anyways and use a slide hammer and replace that pin, make sure you keep the whole assembly straight not tilted !
Old Dec 30, 2021 | 05:04 PM
OrangeBird's Avatar
Car: 1989 Firebird
Pat, with all due respect to your trying to help, this thread is close to 3 years old so I'm sure by now the OP has it handled, and the info you posted was all posted three years ago anyway.
In the future you may want to check the date of the last post in any threads you reply to, so as to not be bumping dead threads.......
Gordiggz
May 14, 2017 04:21 PM
visceris
Jun 10, 2014 01:45 AM
trueburton
Jun 26, 2004 05:18 PM
Fbod88
Oct 25, 2002 01:46 PM
Joel Geerling
Jun 27, 2002 10:37 PM
