stupid question..
Old Jan 5, 2002 | 03:44 PM
JeffC1500TBI's Avatar
stupid question..
If my buddy lifted by the crank pulley to swing my motor around while it was on the stand did he cause any damage? he didn't lift the whole engine just the front of it..
thanks
Old Jan 5, 2002 | 03:47 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
it's possible..
it puts a lot of load on the bearings, and not good load, either
Old Jan 5, 2002 | 03:50 PM
Originally posted by ColinOpseth
it's possible..
not what I wanted to hear.. the engine has just been totally rebuilt and hasen't even been fired up yet..
Old Jan 5, 2002 | 04:01 PM
what's the chances and how would I know if it did damage? we just kinda of slid it while it was sitting on the engine stand with a board under it.. then he sorta lifted a little by the crank pulley to turn it around..
Old Jan 5, 2002 | 04:02 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Man, don't get too worried. It will probably be alright.
Later
Mike
Old Jan 5, 2002 | 04:18 PM
Engine: 305TPI
Dad always cautioned me on this.. i don't know if what he told me is true but i always am careful when doing that kinda stuff..
i figured you'd done some extensive lifting but it'll probably be ok
Old Jan 5, 2002 | 04:34 PM
so I guess I won't know t'ill the engine is all back in and I go to fire it up?
Old Jan 5, 2002 | 04:48 PM
NJ SPEEDER's Avatar
it will be fine. the bearings can take a ton of load just sitting on the stand. what causes wear is really having a side load on the bearing while it is spinning(ie; setting belt tensions too high). don't worry about it.
later
tim
Old Jan 5, 2002 | 08:58 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
Its fine.
Old Jan 5, 2002 | 09:22 PM
thanks guys.. with all the pre install issues i've already run into I don't need to find out the engine is f'ed up because of something stupid like that.. I'll be glad when I get it all in and running.. right now I'm in the process of painting brackets and changing the motor mounts with the energy suspension ones.. finally got around to putting all the sensors and fittings back on today... now if I could only get some 10+ degree C weather down here it would be nice..
djmarch
Oct 2, 2015 10:41 PM
83ho87gn
Sep 26, 2015 08:49 PM
spartanreaper
Sep 25, 2015 07:22 PM
83ho87gn
Sep 24, 2015 08:58 AM
gta892000
Sep 16, 2015 12:37 AM
