Died with a thump at stop light
Old Apr 20, 2018 | 04:31 PM
James Sutton's Avatar
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
After driving 75-85 mph for two hours, engine died at first stoplight with a thump, as if it had seized up, and wouldn't start, but started after five minutes; something cooled off, evidently. Sensor? Which one? MAF? Or VATS?
Notes: (1) Just installed 3-row radiator with 160 degree sensor & 190 degree thermostat; temp. doesn't go over 160. (2) recently replaced ECM. (3) Fuel injectors have never been checked. (4) Engine sputtered at low idle, before dying.
Old Apr 20, 2018 | 07:32 PM
Drew's Avatar
Re: Died with a thump at stop light
How much gas in the tank?
Old Apr 20, 2018 | 07:42 PM
Nine gallons.
Old Apr 21, 2018 | 01:03 AM
Drew's Avatar
Hmm... Since the fuel cools the pump, long drives on a low tank can over heat the pump, causing it to stick. When they cool back down, sometimes they come back. But 1/2 tank, it's probably not that issue.
Old Apr 21, 2018 | 02:33 AM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
any codes?
Old Apr 21, 2018 | 08:00 AM
Didn't check.
Old Apr 21, 2018 | 08:06 AM
Gas gauge read empty, but took only 10 gallons to fill & read full afterwards. There was a thirty mile headwind over the last 110 miles, and I was doing 75-80 mph, so that pump could have heated & heated more when I stopped. You're probably right.
Old Apr 21, 2018 | 01:40 PM
The starter didn't turn over or click, though the electric fan & cluster functioned.
HaulnSS
May 6, 2008 04:02 PM
ad356
Mar 25, 2008 08:52 AM
JungleMan
Oct 15, 2005 12:57 AM
copperchick
Oct 24, 2002 11:39 AM
mypontiac
Jul 31, 2001 11:43 PM
