What is the ball hanging under my car
Car: 86 camaro sport
Engine: Gen 1 350
i have been removing things from my engine bay that i don’t need in order to clean things up and I noticed this ball hanging under my driver side just behind the bumper. The ball has a thin hose coming from it and it runs to the intake manifold and a wire that goes to the harness. Do i need this or can I remove it ?? It’s right below the cruise control.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: What is the ball hanging under my car
The vacuum ball is for the cruise control.
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
And to think I was afraid to open this thread based on the title.
Engine: Gen 1 350
is there any point in having it if all my AC components have been removed and my cruise control has also been removed? The line going to the ball is pretty dry rotted and pinched, I could replace the line or just remove it all. What do you suggest?
Car: 88GTA
Engine: 5.7TPI
"Also for the HVAC door motors."
And if you remove it, when accelerating up a hill, the heater doors will start switching from floor to default Defrost position due to lack of vacuum. That's why it's called a vacuum reservoir.
Engine: 4++,350 & 305 CIs
Car: 88GTA
Engine: 5.7TPI
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I tried that and it's false. I put the AC on max when I left work and held the car against the rev limiter and it didn't switch to defrost at all. 6000 rpm with my 4.8 LR4. Heating system is stock except I removed the vacuum ball, and I don't have the vacuum cruise either.
Car: 88GTA
Engine: 5.7TPI
I stand corrected.
My friends Grand Cherokee had a cracked reservoir and going up long grades, his did that. Must be a Jeep thing.
Car: 1983 G20 Chevy
Transmission: 4L60
I have a LT4 Hot Cammed 87 TPI 350 Firebird that could not keep the blend doors actuated until I hooked up a brake vacuum canister and hooked the blend door vacuum hose up to the brake booster using a check valve from a random Dodge truck. Newer 2000s Dodge trucks store their vacuum in the brake booster for their a/c system. GM systems all default to defrost if they lose vacuum, actually I believe it was a goverment mandate back in the day that ALL cars and trucks did.
Car: 1987 Trans am GTA
Engine: 5.7 liter
I've had mine out for a few months now and havnt noticed any issues, but I don't use the heat or a/c.
fnlrun
May 23, 2004 10:18 PM
BuckeyeROC
Jan 26, 2002 12:40 PM
