Buying car, need advice
Old May 29, 2018 | 01:01 PM
Lauer's Avatar
My friend has a Trans Am and I love the thing so I've been messing around with the idea of buying a third gen Trans Am for a few months now and I think im finally gonna pull the trigger. The best looking offer I found so far is a 1984 Trans Am and the guy wants 2,500 for it
I'm new to the whole car thing so im looking for some advice such as what I should look out for, and if the price the guy is asking for is reasonable or if i could get away with asking for less.
Old May 29, 2018 | 05:05 PM
Venom_1138's Avatar
Car: 1985 Trans Am
Engine: 5.0 305 High Output V8
Transmission: T5 Manual
Axle/Gears: Yup, still there
Re: Buying car, need advice
Well, to be honest, you didn't really give much to go on other than the year and price, so nobody is going to be able to tell you whether it's a fair price unless you can provide more information. How many miles? Which engine and transmission? What condition is the body in? Any rust (particularly on the underside/frame)? What work has been done and what needs to be done? Are there T-tops? If so are the seals still good or do they leak?
Depending on how the above are answered, it could be a steal, or you could be overpaying. But nobody will be able to tell you what scenario you're looking at until there's more information about the car. If you can share any photos of any problem areas (body damage fluid leaks, etc, just to give some examples, that could be very helpful as well.
Old May 29, 2018 | 07:09 PM
Lauer's Avatar
Yeah sorry I didn't really think about all that was in a rush before I posted this.
It has a Chevy small block V8
170,000 miles on the odometer (but the engine isn't original so there's no telling how many miles the engine has)
It has a tinted Ttop
Has a T5 five speed manual transmission
In the pictures shown there isn't any visible body rust
The guy claims the only thing the car needs done is a carburettor rebuild
Old May 30, 2018 | 07:45 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Is it this one? https://newhaven.craigslist.org/cto/...599366241.html
If so, it would be a reasonable bet you will have a lot more to do than just a carb rebuild.
If you are on a limited budget I think this one would be a better starting point...
https://newyork.craigslist.org/que/c...601683209.html
Or this one...
https://providence.craigslist.org/ct...586755705.html
Or look at some Formulas...
https://hartford.craigslist.org/cto/...589207320.html
https://boston.craigslist.org/gbs/ct...570974605.html
Not sure where you are in CT but if you need help picking something up I've got a trailer.
Old May 30, 2018 | 07:53 AM
Lauer's Avatar
Yeah that's the one I was talking about, I'm going to check it out some time this week. I though it seemed pretty promising why do you think it wouldn't be a good starting point?
Old May 30, 2018 | 07:58 AM
PurelyPMD's Avatar
Engine: LB9
Because there is more non original parts on the car than original and more stuff half done than done. Cars that get monkeyed with to that extent tend to be problematic - at least that's been my experience.
Old May 30, 2018 | 08:07 AM
Lauer's Avatar
Didn't really think about it that way, I thought the non original engine wouldnt be a problem but I see what you mean. I'm willing to put some money into the car especially since its cheaper then the better ones listed but I don't want to feed the car all my money.
Old May 30, 2018 | 08:11 AM
PurelyPMD's Avatar
Engine: LB9
The general advice you will find here is to buy the absolute best car you can for the most money you have - you will be money ahead in the end.
Buying a $2,500 car will cost you three times as much to get to the same point as a $5,000 car will. Don't be in a rush, some cars sit on craigslist for ages, some come and go quickly. Check it every day and remember that asking price is not selling price.
Old May 30, 2018 | 08:33 AM
mrestrictrplate's Avatar
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
I traded a car for an 87 Iroc that needed paint and a few things.. Car was decent... After painting T ttop seals and 100 other little things I have put at least 4k into it (not including purchase price) and it's still not done. If you can spend 6k on one with paint you will save tons of aggravation and time and a lot of money.
Old May 30, 2018 | 11:52 AM
BigDogBob's Avatar
Car: 86 Trans Am
Engine: Carb'd LM7
Transmission: TH400
Axle/Gears: Stock 2.73
Yeesh. Starting to think I overpaid for my TA....
Old May 30, 2018 | 01:38 PM
PurelyPMD's Avatar
Engine: LB9
Good cars still pop up for cheap money, just stay vigilant in looking, because the moment you stop, one will pop up.
Old May 30, 2018 | 02:10 PM
PurelyPMD's Avatar
Engine: LB9
Actually I like this one a lot better. Lower miles, lower price, better condition.
You just need to determine what is wrong with it - don't take their word for it!
https://worcester.craigslist.org/cto...570765461.html
Old May 30, 2018 | 06:10 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
buying someones project car always turns into a huge headache and a thinner wallet. the previous owner most likely did a bunch of half assed repairs to it and is now dumping it for a reason.
the best version of a car you can buy is a low miled stock car, if you can't afford that and are interested in improving it yourself then get the next best thing which is a higher miled stock car and expect to replace things.
kkirch15
Jul 9, 2015 04:32 AM
nlansdowne
Northern California
Jul 22, 2008 07:44 PM
83Firebird420
Feb 8, 2008 06:02 PM
