Stalling only with a/c on
Old Jul 8, 2018 | 11:31 PM
podiatra's Avatar
Car: 1986 Camaro IROC-Z
Engine: 350 swap
Transmission: manual
Hi,
I have an iron with 350 crate engine. Once it warms up it idles about 900 but when I turn on the a/c it drops to about 450-500. If revs up, it will shut off. Otherwise, the car does not stall. Any suggestion will be appreciated!
Old Jul 9, 2018 | 01:10 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Stalling only with a/c on
Originally Posted by podiatra
Hi,
Must iron clothes pretty fast lol
Efi or carb ?
Old Jul 9, 2018 | 05:55 AM
podiatra's Avatar
Engine: 350 swap
Lol! Yep... it is carb
Old Jul 9, 2018 | 10:09 AM
Engine: Lb9
Transmission: M20
Do you have a stepper motor
Old Jul 9, 2018 | 02:37 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
If it was carbed from the factory, there would have originally been an adjustable solenoid in front of the throttle linkage to bump the idle when the a/c is switched on. If it's not there now, or not working properly, then that would be causing your problem.
There's a plunger on the end of the solenoid, make sure it moves when the a/c is switched on. If it moves, but not enough, turn the plunger counter clockwise with a wrench until it bumps the idle enough to put it at the proper idle speed.
Old Jul 9, 2018 | 02:53 PM
podiatra's Avatar
Engine: 350 swap
Thank you! Pardon my ignorance but what’s a stepper motor is?
Old Jul 9, 2018 | 03:10 PM
Engine: Lb9
Transmission: M20
It’s a motor that is next to the throttle linkage. When the ac is commanded on the motor pushes out and raises the idle speed. It might be considered more of a solenoid.
Old Jul 20, 2018 | 07:51 PM
podiatra's Avatar
Engine: 350 swap
Hi all,
Sorry for my late reply but I was out of country.
Anyway, thanks for your help.
I looked but I see no stepper motor close to the throttle linkage.
Do I need to incorporate one? Is there another solution to the problem?
Old Jul 20, 2018 | 08:33 PM
NoEmissions84TA's Avatar
Throttle kicker solenoid is at the bottom right.
Old Jul 20, 2018 | 09:03 PM
podiatra's Avatar
Engine: 350 swap
I definitely don’t have it. My engine is using a Holley 670 street avenger carb. Can I add it to th carb?
Old Jul 20, 2018 | 09:13 PM
Engine: Lb9
Transmission: M20
I think the avenger is close to a 4150 , 4160 but I’d double check with holley to see if this kit will work.
https://www.holley.com/products/fuel...ge/parts/46-74
Old Jul 21, 2018 | 08:29 PM
podiatra's Avatar
Engine: 350 swap
I contacted Holley and yes, that’s is the solenoid that with the carb. They also suggested the bracket. But I guess there is a connector- wire that needs to be hook be connected to the solenoid? What type of connector and where does connect to?
Old Jul 21, 2018 | 08:51 PM
Engine: Lb9
Transmission: M20
I’d suspect female spade
Old Jul 21, 2018 | 09:02 PM
podiatra's Avatar
Engine: 350 swap
Got it. So the female spade connector goes from the solenoid to where? Aorry for all these basic question. I just had no idea about this.
Old Jul 21, 2018 | 09:51 PM
Engine: Lb9
Transmission: M20
Ac compressor power side.
mikeselky85
Nov 28, 2009 06:42 AM
gordo420
Feb 23, 2007 06:42 PM
BOTTLEDZ28
Mar 12, 2006 03:09 PM
BOTTLEDZ28
Mar 12, 2006 08:48 AM
kizz
Feb 24, 2002 11:13 PM
