Random No-Start Condition
Old Jul 28, 2018 | 09:45 PM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
Good evening,
Car ran ok,so I felt ok driving it from point A to B. So on two separate occasions this "Random No-Start" has happened in the last 6 days...
The Background:
Monday - Car stared at every key turn throughout the day, work, breaks, etc. Got off work, started car and begin my drive home. Stopped for something at the grocery store, came out, No-Start... Engine just cranks, car towed home.
Tue - Went to JY pulled a ECM from a 90 caprice as I had found out through another thread I was using the incorrect PROM in a previous ECM replacement. Car started right up, so I continued on.
Wed - Fri - At some point I reinstalled the Hypertech chip, drove bau following my normal routine. A side note, I began using 91-93 Octane fuel as well as Hypertech suggest 91 or higher.
Sat - Car stared at every key turn throughout the day, work, breaks, etc. Got off work, started car and begin my drive home. Stopped at AutoZone for a Walker O2 Sensor to cure this code 44, came out, No-Start... Engine just cranks, again the car was towed home.
The Question:
Will a faulty Ignition Coil cause this random no-start?
Old Jul 28, 2018 | 10:56 PM
PaulyC's Avatar
Re: Random No-Start Condition
Not usually, coils either work or don't. Usually. You detailed two times it didn't start, will it start now without doing anything? Or has it randomly not started and started after you experienced a no start? If you cant start right now, check for fuel and spark to get a beginning point for troubleshooting otherwise you are just throwing parts at it and that's no fun.
Old Jul 28, 2018 | 11:32 PM
Engine: 305 / 350
Will it start now without doing anything? Unknown - After jumping the gun earlier and attempting an Ignition Coil replacement (I had one from my last attempt at a tune up that never made it on), and reconnecting negative battery terminal I attempted to start it. Fired right up and It ran for about 30 seconds maybe 45 then it died. Then went right back to the No-Start, just cranking. This was the case no matter which 1 of 2 1228746's & Hypertech Chip, stock AXKT 1113, 90 Caprice ATYR, or 91 Firebird APTY (despite it being for a manual) PROM's. I just needed the car to start and it did not, it just cranked.
Has it randomly not started and started after you experienced a no start? This is a new issue, not something experienced before. The only No-Start shes ever given me was battery related.
Check for fuel. The best I can do here is tell you that with the air cleaner removed I see both injectors spraying in a cone shape.
Check for spark. I'm not quite sure of how to test this, I believe Harbor Freight sells a El-cheap-O inline spark tester but I'm not sure. Wouldn't know what to do even if I had it.
*I did forget to mention in my original post that I noticed my coolant temp gauge never left 100 degrees or so. and the sensor is new and the gauge worked up to that point.
**Ignition Coil not replaced, new coil didn't come with mounting brackets, so back in the stock unit went.
Old Jul 29, 2018 | 01:12 AM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Sounds like your ICM may be on it's way out...get it tested.
Old Jul 29, 2018 | 05:24 PM
Engine: 305 / 350
After a long morning at the JY I pulled an unknown distributor cap (Blue w/ Brass Terminals vs Black w/ Steel?) and what appears to be a fairly newer ICM (Model # 0857282B - White in color vs OEM Black?). I also grabbed the Ignition Coil as it's mounting bracket had screws where as my stock unit had rivets preventing me from installing my spare. Stopped for the thermal paste needed and no auto parts store in the city sells it. I was told I could use CPU Thermal Paste and luckily I had some laying around. Installed ICM, New Coil, New Re-man'ed 1228746 w/ AXKT PROM and she fired right up, a lot easier than before also. After a few laps around the block, turned her off and back on with no issues.
However it was too good to be true, Just went outside, tried again... No-Start
*ICM Tested good at local parts store
*Ignition Coil is new
*In-Line Ignition Spark Test Light - Bulb flashes as engine cranks
Just In Case someone thought of asking have I pulled a plug... just did...this is what came out...
Old Jul 29, 2018 | 06:21 PM
Problem with an intermittent is, you have no way of knowing which state it was in when it was "tested".
IOW, it probably was in "start" mode at the moment, rather than "no-start". "Testing" those is famous and renowned for giving false "good" results.
I'd recommend just changing it out.
And some new plugs too... looks like you've got your money's worth out of that one, anyway.
Old Jul 29, 2018 | 06:28 PM
Engine: 305 / 350
Are you saying replace, the replacement? My original ICM failed in-store testing on the WELLS Machine, the unit I pulled from the yard tested good, and that's what I installed. Before I installed it the in-line ignition spark checker wouldn't flash with the original ICM. It only began flashing with the JY replacement, and that's what led me to the plugs...
Old Jul 29, 2018 | 07:12 PM
Sorry, the whole thing was too convoluted... I got lost.
Old Jul 29, 2018 | 07:26 PM
Engine: 305 / 350
What'd you expect from a noob DIY'er LOL, it's extremely complex and difficult for me but thanks for the help.
Old Jul 30, 2018 | 06:32 AM
PaulyC's Avatar
Are you still getting spark?
Old Jul 30, 2018 | 01:22 PM
Engine: 305 / 350
Last time I checked, I was getting spark between the Distributor Cap & Ignition Coil. I will be grabbing a set of plugs after work and I'll check for spark at the plugs.
Any recommendation on replacement plugs?
https://www.autozone.com/external-en...lug/304782_0_0
https://www.autozone.com/external-en...lug/924019_0_0
https://www.autozone.com/external-en...15743_569539_0
Also, none of the "OEM" replacements seem to have a 0.035in Gap as suggested in the Haynes Manual for the AC R45TS's...
Old Jul 30, 2018 | 07:06 PM
PaulyC's Avatar
So many choices for plugs, stock engine R45TS is the old reliable for me.
Old Jul 30, 2018 | 08:57 PM
Engine: 305 / 350
Yea I ended up going with the AC CR45TS's. I did the first two on the driver side lol it got dark, I had to bail. The two past that seemed impossible anyway, and the passenger side... they all seemed impossible. Car is currently up on jack stands, it seemed like they'd be easier to access them from below but I find myself stuck...
Anyone have any tips on changing them?
Old Jul 30, 2018 | 09:46 PM
PaulyC's Avatar
Be patient, it sucks and the bottom is the best way. Wish I had something better for you.
Old Aug 4, 2018 | 10:06 AM
Engine: 305 / 350
***UPDATE***
Those PITA spark plugs are finally changed, checked all connections. She started up, made it a few laps around the block as before. Went in for a drink and sat, came back out and she fired right up. Those plugs aren't the easiest in the world however with a clear head, plenty of time and advice from everyone here even a noob can do it.
This might be solved, but stick around and we'll see!
WhiskeyChick
May 16, 2014 10:25 PM
pimpflea
Oct 27, 2008 08:58 PM
naf
Sep 24, 2007 12:21 PM
dwillms
Jul 12, 2004 07:48 PM
