305 Block: sell, part, keep? What’s it really worth?
Old Aug 12, 2018 | 02:33 PM
SteelDirigible's Avatar
Car: 84 Berlinetta
Engine: LR4
I have a 305 block from my 84 that was seized on two cylinders. I broke one loose. One piston is still stuck good.
What should I expect to get by selling the block, or if I part it out, what’s the bare block, crank, cam, rods worth? Is it worth me keeping for myself down the road, given the work it will take to rebuild and it still being the 305 anyway?
Old Aug 12, 2018 | 03:27 PM
Drew's Avatar
Re: 305 Block: sell, part, keep? What’s it really worth?
Nothing. It's trash. If you can get someone to take it without charging you money to haul it away, you're a damn criminal.
Old Aug 12, 2018 | 05:12 PM
nhgator's Avatar
Car: 1985 T/A
I had one in good shape,the local Schnitzer yard bought it for $125 a ton along with some valuable old Polaris and Arctic Cat snowmobile parts.
Old Aug 12, 2018 | 07:53 PM
$125 a ton works out to around $15 for that block.
NOBODY is gonna come haul it off, even for free, for that little jack. You'll have to pay em to take it.
The crank & rods are worth even less than $125 a ton. Pistons are worth considerably more, but you've only got about 12 lbs or something of those. And to get that extra ¢¢¢, you'll have to totally disassemble them... can't have pins, rings, or anything else attached.
No it is not worth keeping to "rebuild" "someday". Unless maybe if you have a YUUUUUUJJJJJJE barn or something that you never go in and have no useful use for whatsoever and you can just fill it with trash that won't ever see the light of day.
In case you haven't figured it out yet, you have something with NEGATIVE value.
Old Aug 12, 2018 | 08:27 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Find a local scrap yard and get 6-cents a pound for it. I've done this a few times, it really is all that it is worth.
Now if you can scrape up some copper, brass or aluminum, can get much more per pound.
RBob.
Old Aug 14, 2018 | 06:15 AM
83 Crossfire TA's Avatar
If it was in good shape I'd come and take it... assuming you were local, but a 305 with seized pistons... scrap. The only way that it's worth more is if you buy something to replace it that needs a core and the 305 qualifies
Old Aug 14, 2018 | 06:19 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Only way its any good is if you plan to refresh and add boost. Else its scrap and a yard will take it for gas money to get there
Old Aug 14, 2018 | 10:09 AM
GeneralDisorder's Avatar
If you knock the pistons out, minus the one that's stuck, there's 7 holes you can thread your anchor chain through!
GD
Old Aug 5, 2019 | 02:26 PM
Car: 84 Berlinetta
Engine: LR4
Just thought I'd update, a guy bought it from me for $20, along with some of the internals I'd pulled out. Said he uses the parts to build trophies of some sort for some sort of event. I was glad to have him come pick it up.
Old Aug 5, 2019 | 03:31 PM
UltRoadWarrior9's Avatar
Car: 1986 IROC Z-28
Engine: 383 Gen I SBC 11:1
Transmission: Rebuilt TH700R4 for 500+HP
Axle/Gears: 4th Gen 10 bolt Eaton Truetrac 3.23
That's cool, sounds like it went to good use! So you had to hold onto it for a year? Curious where did you post to sell it?
Old Aug 5, 2019 | 03:35 PM
Car: 84 Berlinetta
Engine: LR4
No, it didn't actually take that long. I forgot how long exactly but it was a while back. Sold it on Facebook marketplace
Old Aug 6, 2019 | 08:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
That's a win!
I've seen pics of some of the items folks build from old engine parts. They are impressive.
RBob.
Old Aug 7, 2019 | 02:07 PM
91z28ss's Avatar
Car: 1991 Z28 convertible camaro
Engine: 383 superram
Transmission: Level 4 Vigilante 3000
Axle/Gears: 3:42,Torsen, moser axles LPW girdle
Damn, I guess I am crazy then!! Was keeping my OE engine removed in 1998 with low 43 000km's in it and decided to refresh it this spring going threw an overhaul gaskets, rings bearings, lifters, bolts, frost plugs, rebuilted heads with valve seals, timing chain oil pan because stock one was bent a bit from moving around the garage... paint etc to make it as a new engine again! And now no one is hitting the target since I listed it! I think I will keep it as an entertainement piece and make a basement living room table out of it!😕
Old Aug 7, 2019 | 04:13 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
"One man's trash is another man's treasure"!
Old Aug 9, 2019 | 09:36 PM
BOOT77's Avatar
Prob cause too many paint up trash engines to rip people off. I'd only buy an engine I couldn't see running form a friend and prob still get ripped off LOL Bought a running 350 vortec 4x4 truck for the engine in my vlog and even that didn't work out but I'm the only one to blame cause I deiced to gamble on it being a bad gauge since I couldn't find anything else and was getting antsy.
Old Aug 9, 2019 | 09:38 PM
BOOT77's Avatar
Send him my way I got a whole pile of busted engines and parts I'm gonna haul of for scrap eventually LOL
Old Aug 10, 2019 | 12:36 PM
91z28ss's Avatar
I know they may be some scammers along the road! But I do have more than 1200$ just in parts with all bills from Summit, On line stores Ebay, local parts stores etc etc with pictures of the rebuilt process of all loose parts, interior of the engine etc. if you buy a used/rebuilt engine from an individual or a shop you need to see this kind of rebuilding process!! Another fact is if you paint a used engine without disassembling the engine, all the gaskets, bolts, injectors would be painted too!
Old Aug 10, 2019 | 01:09 PM
BOOT77's Avatar
Not if your clever, could always remove bolts or use a bit of tape, picture could be from the 1st one you actually did for yourself and you've sold the past few just painted up the same. I am not saying your a scammer to be clear, just debating my point. I've basic rebuilt engines and it can nickle & dime you if your doing it right for yourself, building LOL $$$$$ I just bought a vortec 350 crate engine in my vlog for right about $1500 and it comes with unlimited miles or a 3yr warranty I think. Plus you can fake receipts if your clever for even machine shop work n you can't see inside an engine easily for most. It's just not appealing to buy a rebuilt??? engine form a stranger, was a guy who did it on c-list around here but he stopped and he was cheap, $900 for a basic longblock, more for performance extras. Still who knows if he was just doing hone jobs and re-rings like so many claim as a rebuild, I couldn't be a car salesmen like some I know cause if I do anything I do it right and I'd make no $, if I see a bad or looks badish hose/part I replace it. To make $ you gotta fire n forget, no new gaskets on an engine swap unless it has a known problem and so on. Sorry but your prob not gonna sell that engine, unless it's too prove me wrong LOL then someone will show up n buy it!
Old Aug 10, 2019 | 01:11 PM
BOOT77's Avatar
Plus most just want the basic longlbock and use their extras to save $ or fit their combo/build
Old Aug 11, 2019 | 04:22 AM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
AcedRaven
Jan 22, 2011 09:56 PM
Project 3.4 Camaro
Mar 23, 2010 07:58 AM
Spiers
Members Firebirds
May 30, 2008 04:30 PM
smokingss
Feb 20, 2004 01:52 AM
chevy5711
May 8, 2001 06:17 PM
