Speedometer and tachometer not working
Old Sep 1, 2018 | 02:23 PM
79Daytona's Avatar
Say I was wondering I'm back working on my 92 Z28 Camaro 5.7 TPI and the tachometer stopped working well the needle has been moving up and down while driving and today it stopped working and the speedometer has not worked sense I've gotten the car and I was wondering could the small plug in circuit board on the tach and speedo has gone bad.
Old Sep 2, 2018 | 07:38 AM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: Speedometer and tachometer not working
If yours hasn’t died, it almost certainly will.
https://www.wc-autoparts.com/1990-92...t-replacement/
Old Sep 2, 2018 | 07:50 AM
maks10's Avatar
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
For the tach check white wire off coil...did a quick search for a pic here’s a thread describing that wire for an aftermarket tach
https://www.thirdgen.org/forums/tech...rket-tach.html
Old Sep 2, 2018 | 10:32 AM
79Daytona's Avatar
Cool thanks for the info guys.
Old Sep 2, 2018 | 11:11 AM
79Daytona's Avatar
Well I when and checked the white wire on the coil they look ok I even checked the wire plugs to make sure they weren't lose on the coil and then cranked the car up and the tach is working now I think it still jumps a little but time will tell . Well thanks again for the info. Say W.E.G dose wc- autoparts have a speedo circuit board .
Old Sep 2, 2018 | 01:58 PM
maks10's Avatar
Car: 1990 Trans Am
One thing that comes to mind is following that wire up the harness to make sure it’s not grounding out on something and/or open since you mention it flickers only sometimes.
Old Sep 2, 2018 | 05:55 PM
79Daytona's Avatar
Good point maks10 I will check it out. Thanks
Old Sep 2, 2018 | 10:18 PM
W.E.G.'s Avatar
Engine: V6 2.8
WC Autoparts is Greg. He's on this board. Send him a message. Guy seems like he knows about all there is to know about third gen gauges.
Link to his user profile: https://www.thirdgen.org/forums/member.php?u=120121
Old Sep 3, 2018 | 03:33 PM
79Daytona's Avatar
Cool thanks W.E.G
JADIII35
Oct 26, 2010 01:43 PM
rodrob1961
Jan 9, 2010 07:03 PM
scottjake
Aug 30, 2008 09:44 PM
JimmyG-91Z
Jul 17, 2003 04:21 PM
bombero437
Aug 20, 2001 10:02 PM
