Engine stumbling or missing
Old Oct 23, 2018 | 02:40 PM
305TBI's Avatar
Car: 1991 Firebird Formula
Engine: 305 TBI
Axle/Gears: 4.10
I am the original owner of a 1991 firebird 305 TBI with a SN-92 Paxton. The supercharger was recently rebuilt by Paradise Wheels.
While driving the car at any steady cruising speed (30 mph to 70 mph) there is a random miss or stumble every few seconds.
I just rebuilt the TBI completely.
The idle is reasonable.
The car accelerates very good with no hesitation.
No trouble codes found with a scan tool.
Any ideas what to look for?
Old Oct 23, 2018 | 03:04 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: Engine stumbling or missing
What scan tool are you using?
Your best chance of diagnosing drivability issues is to view the same thing the ECU is seeing at the time the event occurs.
Old Oct 23, 2018 | 03:25 PM
GeneralDisorder's Avatar
You have a lean cruise situation most likely. Have to check out the BLM's, etc. Could be a bad O2 sensor. The narrow band systems only use the O2 for idle and cruise. Throw a calibrated wideband up the tailpipe and check the idle/cuise O2 readings against the wideband. If there's more than half a point of AFR difference between the two under idle or cruise then you most likely have a bad sensor.
GD
Old Oct 24, 2018 | 09:49 AM
305TBI's Avatar
Engine: 305 TBI
Axle/Gears: 4.10
AutoXray XP240. It plugs into the OBD1/2 connector and scans the same data that the ECU sees.
I use the capture mode to store the data and then review the data later.
I thought all scan tools did this.
Old Oct 24, 2018 | 09:55 AM
305TBI's Avatar
Engine: 305 TBI
Axle/Gears: 4.10
GD
That could be my problem.
Thanks for the advice.
Old Oct 24, 2018 | 10:02 AM
305TBI's Avatar
Engine: 305 TBI
Axle/Gears: 4.10
By the way, the Block Learn is a stable 128 and the Integrator is a stable 127.
Old Oct 24, 2018 | 10:41 AM
Is that in closed loop? At idle or cruise or both?
GD
Old Oct 24, 2018 | 12:21 PM
305TBI's Avatar
Engine: 305 TBI
Axle/Gears: 4.10
GD
That is closed loop. I have not recorded data at idle; the car idles ok. I have recorded data 4 different times .. One at a steady constant 40mph, then 50mph, then 60mph and 70mph. All scan tool data is similar. The rich/lean data flips as expected, The oxygen sensor goes well beyond the mid point and below the mid point.
Old Oct 24, 2018 | 01:58 PM
When was the last full tune up?
Old Oct 25, 2018 | 01:06 PM
305TBI's Avatar
Engine: 305 TBI
Axle/Gears: 4.10
I take care of my car on the inside and out on a regular basis. I purchased it on 7-16-1990 (it is a 1991 model). However, I don't change the spark plugs as often as I would like. The car is modified and changing the plugs is a REAL BEAR.
I might add that today I was driving my car and I got a code 13, oxygen sensor fault.
The block learn and integrator both were at 131 and the oxygen sensor read between 330 and 409.
I will have to get the proper sensor and replace the original one (it is 28 years old).
I will keep you and the board posted.
Thanks to all who have helped and are interested in this post.
Old Nov 10, 2018 | 01:17 PM
305TBI's Avatar
Engine: 305 TBI
Axle/Gears: 4.10
Update -
I replaced the oxygen sensor (it was faulty) and I adjusted the "minimum air" hoping that this might correct the engine missing problem, but that had no effect. As I mentioned in an earlier post the car runs great under acceleration and deceleration, but at constant steady speed the missing is quite noticeable. I pulled the number 3 spark plug and found it to be carbon fouled. The remaining plugs I suspect are in the same condition. I think that the plugs have maybe 10,000 miles on them. If I have the plugs replaced I will have to have it serviced because I am too old to do that now (81 years). Still no trouble codes set. Any additional help would be very much appreciated.
Old Nov 10, 2018 | 04:28 PM
Sounds like maybe it's ready for an ignition tune up or at least clean and gap the plugs. It's not unusual to need this more frequently on modified forced induction engines.
Is it wet, oily carbon, or dry powdery carbon on the plugs?
GD
Old Nov 11, 2018 | 09:42 AM
305TBI's Avatar
Engine: 305 TBI
Axle/Gears: 4.10
GD
Thanks GD.
It's dry.
I also replaced the distributor cap. The spring loaded center pin inside was not functioning smoothly. I thought that was the problem, but not the case.
I will have the plugs replaced.
Old Dec 5, 2018 | 05:15 PM
305TBI's Avatar
Engine: 305 TBI
Axle/Gears: 4.10
GD
Problem Solved-
I had the spark plugs replaced and discovered that the #5 plug had a particle shorting the electrodes.
Thanks for all your help and interest.
305TBI
Old Dec 6, 2018 | 10:58 AM
Excellent! Thank you for the resolution.
titchener
Jan 30, 2011 08:00 PM
aharvel50
Nov 11, 2009 07:39 AM
19WS6T/A91
Apr 7, 2003 07:36 PM
GTA91
Sep 12, 2002 04:25 PM
Tab92bird
Sep 18, 2000 05:03 PM
