89 camaro wont start without pedal to the floor wont idle and bogs while or givigas
Hey guys first time posting I've had a tone of problems with my car ever since i got it. Guy told me car just needed paint come to find out there's a whole in the floor and needs rocker and inner rocker. He stuffed bees PM aperitif and blonde on it to cover it up👌 so for starters that's what I'm dealing with haha. But just got the car running good for about a month after getting new ICU, fuel pump sparkplugs, and wires, a long with new brake lines and brakes I'm stuck back at square one. So what happened after ik gkt the thing running great I did a burnout and immediately after it began bogging like as if it were running on 4 cylinders had no power and the car shut off. The only way I could get it started was to put the pedal to the floor and after letting off it would shut off unless I kept pumping the gas but and still It sounds like it has no spark in some of the cylinders. I got home took out a couple spark p.k lugs and gas started pooringnout of the block. Btw biggest pain in the *** to change spark plugs especially with no jack and at 8pm. This car is a giant money pit and I dont have the money but I cant get my self to sell it. I'll lus it never runs long enough to sell it please help if anyone has any ideas that would be great. It also had a full tank of gas and now it says there's no gas. Kinda scary to think all my gas could be in my engine but I dont thinkthat's possible. It wouldn't turn over thought it was seized but I smelt gas s ok u know it was flooded but after taking all the plugs out I cranked the car over a couple times and bought new spark plugs still doing the same ****. Sorry for my life story with the thing but j find sometimes it helps know a bit of back ground on it
Re: 89 camaro wont start without pedal to the floor wont idle and bogs while or givig
Hey guys first time posting I've had a tone of problems with my car ever since i got it. Guy told me car just needed paint come to find out there's a whole in the floor and needs rocker and inner rocker. He stuffed bees PM aperitif and blonde on it to cover it up👌 so for starters that's what I'm dealing with haha. But just got the car running good for about a month after getting new ICU, fuel pump sparkplugs, and wires, a long with new brake lines and brakes I'm stuck back at square one. So what happened after i got the thing running great I did a burnout and immediately after it began bogging like as if it were running on 4 cylinders had no power and the car shut off. The only way I could get it started was to put the pedal to the floor and after letting off it would shut off unless I kept pumping the gas but and still It sounds like it has no spark in some of the cylinders. I got home took out a couple spark plugs and gas started pooringnout of the block. Btw biggest pain in the *** to change spark plugs especially with no jack and at 8pm. This car is a giant money pit and I dont have the money but I cant get my self to sell it. I'll lus it never runs long enough to sell it please help if anyone has any ideas that would be great. It also had a full tank of gas and now it says there's no gas. Kinda scary to think all my gas could be in my engine but I dont thinkthat's possible. It wouldn't turn over thought it was seized but I smelt gas s ok u know it was flooded but after taking all the plugs out I cranked the car over a couple times and bought new spark plugs still doing the same ****. Sorry for my life story with the thing but j find sometimes it helps know a bit of back ground on it
More info on the car is needed.
89 rs or iroc?
V6 or v8?
Tbi or tpi?
89 rs or iroc?
V6 or v8?
Tbi or tpi?
Sounds like you have major injector and/or fuel pressure regulator issues. Also need to check to make sure the injectors aren't getting a constant ground signal, etc. The stock (TPI) injectors are known problems on these cars. After you check for power/ground to the injectors, proper injector pulse from the ECM - if all that checks out then probably time for some new injectors. South Bay Fuel Injectors makes nice Bosch III replacements kits and also has the FP regulators, etc if you have a TPI setup.
Drain all the gas and change the oil. It will surely be full of gasoline and you'll destroy the engine if you run it that way.
GD
GD
Sorry about that it's a camaro rs 5.0 305 with tbi I noticed today that the passenger side injector is leaking into the carb I feel like it could have blown the seal but I could be wrong I have a gasket kit but the screws are tapped in the injectors I just recently had the tbi rebuilt at rock auto but the gaskets seam pretty cheap. I should just test for spark and a fuel pressure I'll check it out tmr.
Yes its probably flooding at start, and by flooring it youre putting it in clear flood mode, shutting off the injectors.
So like GD said check the fuel pressure back at the fuel filter. The pressure will probably drop instantly when it stops priming, so you'll need to crimp the return fuel line so that pressure will hold. I believe it's around 13 PSI, plus or minus a couple. After that, just rebuild the TBI. Its easy and there are even a few videos on youtube. If it's anything like the truck's, you just need to disconnect a few sensors, fuel lines, injectors, and remove a couple of bolts holding it to the intake. Then using the correct star sockets, take the unit apart, replace the gaskets and 2 injectors. You can get rebuild kits that have all of the gaskets on ebay. The injectors, southbay may have. Or you can just use the cheapos from Ebay, whatever you want. Leave the pressure regulator spring in there, unless its broken. The one that comes in these kits are flimsy and will drop your PSI a few points and the car will run like garbage.
When I did this on my truck several years ago when it was TBI, it ran so much better.
Hey thanks for everyone's help during this I didnt have a lot of time with work, but I ordered one new Injector and a gasket rebuild kit for the tbi and got the car back and running withing a half hour happy holidays everyone I appreciate the quick responces.
Glad to hear you got it back on the road.
ace322
03-16-2016 02:39 PM
