Rough idle after warmed up, dies, bad smell
Old Jan 9, 2019 | 12:56 PM
Sean's Garage's Avatar
So I have a 92 camaro rs 305 tbi auto, bought it a couple months ago and the guy said it dies beause it needs an iac valve. I replaced it and the problem was the same. It’ll fire right up, idles bad, when put into reverse or drive it dies unless given gas, when I gas it, it smells bad like maybe rotten eggs. Any help is greatly appreciated.
New parts:
distributor rotor and cap
Iac valve
egr valve
map sensor
coolant temp sensor (by thermostat)
fuel pump
fuel filter
fuel pump strainer
intake air temp sensor
alternator
thanks 🙂
Old Jan 9, 2019 | 01:03 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Rough idle after warmed up, dies, bad smell
The smell could be a plugged catalytic converter.
Old Jan 9, 2019 | 01:14 PM
The cats are cut off
Old Jan 9, 2019 | 01:18 PM
Engine: Lb9
Transmission: M20
Check engine light on ?
Does this happen only when the engine is warmed up ?
how old is the o2 sensor ?
have you checked for leaking injectors ?
you can check the spray pattern with a timing light.
Old Jan 9, 2019 | 01:34 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Have you done this?
https://www.thirdgen.org/tpimod2/
Old Jan 9, 2019 | 10:20 PM
No check engine light, yes only when warm, probably old, and I haven’t checked them but they spray in a good cone shape
Old Jan 9, 2019 | 10:22 PM
Originally Posted by henryd3
I haven’t done that, basically just torqued it to spec and plugged it in, never changed one before and I bought it from a smaller part shop and it just came in a plain white box with no instructions. Is this what happens when you don’t adjust it?
Old Jan 22, 2019 | 07:37 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
I'm not familiar with the TBI setup, but I had an improperly adjusted TPS do exactly this on a TPI engine. It smelled bad at idle too. When I installed it had inadvertently set it to .054 volts, instead of the correct setting of .54 volts.
Old Jan 24, 2019 | 01:49 PM
shredthegnar's Avatar
My 92 RS was doing the same thing. I replaced the iac and throttle position sensor, then reset the ecm. It seems to have helped a lot, but sometimes when I start it after the car has already got up to temp it will stall like it is vapor locked, I think its because the charcoal filter is clogged.
Old Sep 30, 2024 | 09:17 PM
This reply is 5 years late, I've since graduated high school and tech school haha. Anyways, shredthegnar solved it. It was the IAC valve causing it to run lean once the ECM entered closed-loop. This lean condition caused that nasty smell and caused it to stall. Hope this helps anyone else having issues with their TBI. If it stalls at idle when hot, the first thing I would check is the IAC.
FreeSpirit
Jun 13, 2013 04:44 AM
itsMikey
Jan 29, 2010 04:16 PM
91Z28
Mar 8, 2002 03:05 PM
87formula350JJS
Jun 7, 2001 12:21 PM
