OBD1 readers
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
Re: OBD1 readers
If you don't like paper clips then this will work for only 45 bucks: https://actron.com/content/obd-i-code-scanner-gm
Good luck.
Good luck.
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
Re: OBD1 readers
Good luck.
Good luck.
https://www.ebay.ca/itm/SALE-HOT-INN....c100012.m1985
Engine: V8 305
Re: OBD1 readers
Bend it into a U shape. stick one leg into terminal A and the other into B. Turn the key to run, not start, just run... Then count the flashes of the check engine light on the dash.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Engine: LS1, LB9, L03
Re: OBD1 readers
Paper clip. Don't waste money on scanner for an OBD I car if all you're gonna do is pull codes with it.
Engine: V8 305
Re: OBD1 readers
are there any digital code readers like there are for obdII.. hard time finding one for cheap.
Re: OBD1 readers
Find a deal on a Snap-On MT2500 (or a newer Snap-On scanner like a Modis, Verus, Verdict, etc) on ebay. Or you will have to go with an ALDL cable and some laptop software like winALDL or use TunerPro and the proper ADX file, etc.
GD
GD
