Electric fuel pump question
Old Jul 1, 2019 | 02:42 PM
Thirdvert89's Avatar
Replaced tpi set up with a 350 sbc and an edelbrock carb Can’t use fuel pump in tank tonoowerful for carb . Bought a electric Holley pump but wouldn’t suck fuel being mounted in engine bay where’s best spot under car to mount for it work
Old Jul 1, 2019 | 08:48 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Electric fuel pump question
Why don’t you regulate the i tank pump down ?
should have stuck with the tpi good efi setup.
Old Jul 1, 2019 | 09:33 PM
69L48Z27's Avatar
Car: 1989 IROC-Z
Engine: 5.7L
Electric fuel pumps push, not pull. The area where your fuel filter is, is probably the best location.
X2 on using your in tank pump. External pumps are messy IMO.
Old Jul 2, 2019 | 12:01 PM
Thanks for the input I did have a regulator but it was still over powering.
Old Jul 2, 2019 | 12:48 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
What reg did you use
Old Jul 2, 2019 | 03:14 PM
I bought iy on ebay for 40 not even sure of the name
Old Jul 2, 2019 | 03:28 PM
What would be a good regulator to buy
Old Jul 2, 2019 | 05:39 PM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tech...but-quick.html
'84Z28
Oct 7, 2009 10:26 PM
iroc-si
Carburetors
Aug 15, 2006 02:26 PM
