suggested fuel pump 91; tpi
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
may be needing to replace the fuel pump... 5.0 tpi.. whats the best pump to go with.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: suggested fuel pump 91; tpi
The Walbro 255 fits no problem. It is used in the Edelbrock F body fuel pump kit. I just put one in my 91 Formula because I got it cheap with the car. Usually I go for the Deatschwerks DW200 (255lph) pumps. They have a kit for the C4 vette that is close enough. They are much quieter and we have never had one fail. Probably used 200 of them in the shop.
GD
GD
Engine: V8 305
ok.. I assume these pumps are an upgrade over stock and doesn't need me to upgrade something else?
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
The Walbro 255 is a nice pump but it's loud. Threw mine in the trash after a month. I couldn't stand the noise!! For a driver I'd never suggest it. For a racecar application, sure.
Delphi makes quality pumps.
I have no experience with the Deatschwerks DW200. If your car is a stock application I don't see any reason to go overboard on pump capacity.
Engine: V8 305
that's wat I'm thinking as well.. I'm not sure if the pump is even gone at this point as it does cut in when the key is turned but we are not sure if it cuts out after starting. I know that https://www.summitracing.com/int/par...model/firebird looks like a stock tpi pump.
DELPHI FE0110 (good $)
DENSO 9515014 (better $$)
DENSO being a huge Japanese OEM manufacturer. They make the factory pumps for many cars.
However, don't order anything until you do full diagnostics. Get a fuel pressure gauge and slap it on.. check or replace fuel filter if pressure is low, all that.
Engine: V8 305
Engine: V8 305
do you guys change the strainer too? I don't see a listing for them tho.
Engine: V8 305
Cutting metal brake lines and patching them with rubber line is waiting for a leak/fire to happen.
Engine: V8 305
yeah the local garage will be changing out the pump if it comes to that and I'm leaning to dropping the tank.. makes more sense.
If it's a garage they'll follow book procedure (drop the tank)
Engine: V8 305
anyone know what pressure the pump works at? right now my car just rolls and rolls with no start.. any ideas?
Engine: V8 305
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I thought the walbro 255 is what Holley and other aftermarket companies re-brand as their own. Ive had a walbro 255 and a Holley (again, I think it's a re-branded walbro) both go bad. Dyno Don suggests a GM pump for one of the turbo truck /suvs like the cyclone. I can't recall the GM part number right now but it's worked perfect behind my supposed 400 horse 383s for many years.
Mine was good so it was re-used. Specra makes a replacement.
