Correct starter?
Old Oct 1, 2019 | 07:24 PM
Bustionironi's Avatar
Car: 1985 IROC
Engine: 350HO
Axle/Gears: 10 bolt 3.23 limited slip
Correct starter?
Hello Thirdgener’s,
Once on a cold start and quite a few times on hot starts the starter has not engaged, just “clicks” once. On the cold start I just tried again and it started. On the hot starts I have had to wait 15 minutes or so to get the starter to engage. I’m thinking of just replacing the entire starter and solenoid with a new one. When I got under the car to check it out it looks like it has a smaller starter than it should. I can literally see the teeth of the flywheel where it would seem the starter housing should be covering. I don’t know much about the car as I didn’t build it. It is a 1990 IROC with a G92 code. Original 700R4 has been swapped to a t56. The original 350 is supposedly stroked to 383. It has shorty ceramic coated headers with air tubes. All I can make out on the block is casting 088. Can anyone tell me if a standard over the counter replacement starter will fit/work for this application?
Thanks for your time,
Ted
Old Oct 1, 2019 | 08:12 PM
Re: Correct starter?
That starter isn't a stock one. It's a Hitachi-based "mini-starter".
I think once you see a stock one, you'll figure out you don't want it. It's about twice that size and weighs about 3 times as much. Plus, there's a good possibility it won't even turn your motor over reliably.
Buy a good quality one somewhat similar to what you've got. There's DOZENS of them available. Stay away from the cheeeeeeeeeep ebay crap. Summit & Jeg's for example have several entire product lines of those.
Old Oct 1, 2019 | 09:11 PM
Mike89GTA's Avatar
It looks like a better starter than the stock one. The stock one would fill the hole but it would sit a lot lower. You want the starter as far from the exhaust pipes as possible so it doesn't get overheated and lock up.
Old Oct 1, 2019 | 11:17 PM
Car: 1985 IROC
Engine: 350HO
So it’s okay to have a hole in the housing like that? There isn’t a filler plate or something?
Old Oct 2, 2019 | 12:17 AM
NoEmissions84TA's Avatar
You could make a sheet metal plate to cover that hole if it bothers you. Use the bolt that is covered by your red arrow in the pic.
It looks like the starter is right up against the header. Not good for starting a hot engine.
That starter can be indexed - meaning that you could remove the 2 bolts holding the motor to it's mounting block and rotate it either way to try to get better clearance. There is a selection of bolt holes to allow for different setups.
Old Oct 2, 2019 | 11:39 AM
Car: 1985 IROC
Engine: 350HO
Okay, I will try to index it first and see if that takes care of it. The hole is okay I guess, just wanted to make sure it was “standard” to have like that.
Old Oct 13, 2019 | 08:43 PM
Car: 1985 IROC
Engine: 350HO
Replaced it with a remanded LT1 starter from a 96 Vette I picked up at Autozone with a lifetime warranty. It covers that awful gap and works well. Thanks for your help.
Ted
Old Oct 13, 2019 | 09:11 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Ted
How difficult was it to wire up the LT-1 starter?...
Old Oct 15, 2019 | 10:28 AM
Car: 1985 IROC
Engine: 350HO
My vehicle was already equipped with a remote starter solenoid. All I did was un-bolt the old starter and bolt in the new one (in stock at Autozone). I had to get a longer starter switch cable (in stock at Oreilly) because the one that was there didn’t reach the new terminal location. I also got new starter bolts (in stock at Oreilly) as the ones that were there for my aftermarket starter were not the correct length. It was a very simple swap.
Ted
DracoZK
Jul 4, 2006 11:13 PM
Abubaca
Jun 18, 2005 08:26 PM
MaxxMitchell
Feb 3, 2004 06:13 PM
