New twist on the motor mount problem
Old Oct 4, 2019 | 08:47 AM
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Hi All,
I need to change my motor mounts which after a lot of reading have found it is going to be a pain in the ***.
To add to that, I have to remove the motor mount brackets as I put them on the wrong sides not knowing there were separate sides...
Given this new complication, and having the cut access holes / use multiple sockets / or go in from the A-arms methods, is there one that would favour me also removing the brackets from the block and swapping them over?
I was thinking of loosening the trans cross member bolts and letting it sit a bit, then hoisting the motor up with a engine hoist, pull the bolts from the mounts and then jack it up a bit more to see if I can get it high enough to access the bolts on the block and do the switcharoo that way?
Will that work, and which way should i go for the mounts themselves?
Old Oct 4, 2019 | 05:57 PM
UltRoadWarrior9's Avatar
Car: 1986 IROC Z-28
Engine: 383 Gen I SBC 11:1
Transmission: Rebuilt TH700R4 for 500+HP
Axle/Gears: 4th Gen 10 bolt Eaton Truetrac 3.23
Re: New twist on the motor mount problem
I don't think it should be that bad for you. The labor guide states 2.0hr for both front engine mounts.
I think you're onto the right track on somehow jacking the engine up by hoist where you can keep an eye on the distributor so it doesn't hit the firewall as opposed to jacking the engine up from underneath while it's up in the air.
Old Nov 11, 2019 | 02:27 PM
MicksIroc's Avatar
I have no motor and the suspension is completely out of my car still took me an hour to remove the old motor mounts. Those of you that have replaced motor mounts with the engine and suspension in the car deserve the ultimate Master Mechanic award. What a pain in the crotch!
Old Nov 11, 2019 | 09:57 PM
evilstuie's Avatar
The timer is still going on mine.
I had to modify the trans member for the 4l60e mount to work so I've still got motor mount brackets on the wrong way with very shoddy rubbers.
I'll giv it a try next month and see if I have any success, but good work on yours.
Old Nov 12, 2019 | 10:19 AM
GeneralDisorder's Avatar
Didn't strike me as being all that difficult. The labor guide is of course for us guys doing it on a lift. 2 hours is probably about right. Was probably more than that for the urethane mounts with the grinding of the rivets and such to reuse the clam shells. It was a Sunday morning while watching cartoons.
GD
Old Nov 12, 2019 | 10:04 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
There's just nothing like cartoons and a sippy cup while wrenching on the car.
Old Nov 12, 2019 | 10:59 PM
That's actually a really good idea. Keep me from spilling my Crown and Coke!
GD
jkrustchinsky
Nov 29, 2010 06:11 PM
Wishmaster's87IROC
Oct 16, 2006 11:00 PM
Phoenix1987
Aug 24, 2006 08:10 AM
LoudmouthSS
May 27, 2005 01:55 PM
valu8or
Aug 1, 2000 01:31 PM
