Fuel filter check valve
Old Nov 20, 2019 | 06:39 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Does a stock type fuel injection fuel filter have a internal check valve to maintain fuel pressure at the fuel rails?
Old Nov 20, 2019 | 11:59 AM
91banditt2's Avatar
Engine: 5.7 HSR
Re: Fuel filter check valve
According to K&N tech support their PF-1000 direct replacement fuel filter does not have a one way check valve, it's safe to assume that a AC Delco or other direct replacement filters also do not have a check valve.
Old Nov 20, 2019 | 12:08 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
No.
It was the pumps that had them, not the filter.
Most pumps don't even have them now. You can buy an in-line high flow check valve if it's something you really need, but modern pumps pressurize so fast it isn't needed.
gt4373
Carburetors
Oct 22, 2015 07:13 PM
SRKLEGIN
Aug 27, 2014 08:45 AM
SuperHawk996xx
Carburetors
Apr 6, 2013 09:09 PM
HotRodLarry
Carburetors
May 8, 2010 09:46 PM
bulletboy29
Carburetors
Aug 30, 2004 09:07 AM
