Looking for a Speed sensor
Old Jan 16, 2020 | 09:35 PM
J_question's Avatar
So my biggest issue right now is I am unable to find anything similar to the speed sensor I currently have , with the lack of any real good number on it all I can find is “DR “ “40-45” and “0470” I’m assuming the 40-45 is the gearing? I haven’t been able to find anything like it online. It sits in the tail housing of the transmission of a 700r4 . The tranny reads “MD8” so I believe this tail isn’t original . I have a couple pictures for viewing if that helps at all. I’m hoping someone can guide me to a new one or possibly a different option??thanks all!
Old Jan 16, 2020 | 10:21 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: Looking for a Speed sensor
Looks like you are missing half of it. What year/make/model ?
Old Jan 16, 2020 | 10:56 PM
Drew's Avatar
MD8 is the GM code for the 700R4. The 40-45 is the tooth range of the driven gear that sensor will fit. Typically there are 2 or 3 sensors to work with 2.73-3.42 gears. You've gotta have the right sensor, and the right gears to match the trans and rear gear ratio. There are also different sensors on early cars vs late, but IIRC the later sensors will work with earlier cars as long as the gear/sensor is right for the right gearing/transmission.
Generally, when you look up the vehicle speed sensors in the catalog, you'll need the RPO code from the SPID in the glovebox to get the right replacement. Chances are above average that the early style sensor like you have in your photos, isn't available anymore. The 5spd version (early or late) hasn't been available in several years, Rock Auto doesn't list any sensors being available before the 1990 style change.
Old Jan 18, 2020 | 11:56 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
This style was used from 84-86 in the Berlinetta, 86-89 in the Firebird, & from 84-90 in the Corvette.
I've got one (40-45 tooth count ) available so feel free to send me a PM if you can't find it elsewhere.
Old Jan 19, 2020 | 06:55 PM
J_question's Avatar
I messaged you thank you!
Old Jan 19, 2020 | 07:11 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
IF John doesn’t have one I think I do.
Old Jan 20, 2020 | 08:59 PM
Engine: Lb9
Transmission: M20
gm 10456088 or 10456089, standard motors sc12 34 to 39 tooth driven gear and sc13 40 to 45 tooth driven gear
looks like I have the 10456089
https://www.ebay.com/itm/Vehicle-Spe...4AAOSw5Npdpnpk
Old Jan 20, 2020 | 09:01 PM
Engine: Lb9
Transmission: M20
http://www.3rdgenformula.com/91/91speedometer_gears.htm
Old Jan 20, 2020 | 09:20 PM
Engine: Lb9
Transmission: M20
I think your looking for a gm 25007339
Old Jan 20, 2020 | 10:09 PM
John in RI's Avatar
$80 + Shipping:
Coupe of scratches,... O-ring is good.
Sensor is 2" across and fits all 700R4 trannys. Requires electric type plastic gears,....... will work with 40-45 tooth count - only.
Gray Ghost 8991
Sep 23, 2017 07:01 AM
TylerSteez
May 31, 2015 06:44 PM
305blackbird
Feb 8, 2008 02:41 AM
