What is this connector??
Old Apr 6, 2020 | 07:11 PM
RLuzum's Avatar
Car: 1987 Pontiac Firebird Trans Am GTA
I'm sure this is a long shot, but I just bought my 1987 Trans Am GTA and I'm currently in the process of figuring out / undoing a lot of the things some previous owner did. So far I've removed all of the wiring left behind from an amp/sub in the back and removed a remote controlled alarm that was attached with a single screw but had no wires connected. Anyway, while looking around under the hood, I noticed this random connector with a single black wire, not connected, and with nothing obvious in the area for it to connect to. It's in the rear passenger side corner of the engine bay.
Any ideas?
​It's coming out of the large wire loom below.
Please excuse the dirtiness, I've only had it a few days.
Old Apr 6, 2020 | 08:11 PM
Re: What is this connector??
Looks kinda like for the underhood light.
Old Apr 6, 2020 | 08:18 PM
RLuzum's Avatar
Honestly didn't even know it was supposed to have an underhood light... That might explain it!
Old Apr 6, 2020 | 08:26 PM
Don't know about "supposed to"... some cars did, some didn't, it was an option, that's just the provision for it to plug into, I think
Old Apr 6, 2020 | 08:31 PM
RLuzum's Avatar
I really appreciate it! That makes sense and it makes me feel better that it probably isn't something critical.
Old Apr 6, 2020 | 08:33 PM
RLuzum's Avatar
Now I can continue with trying to get my hatch release button and my left directional button on the power mirror adjuster to work.
Old Apr 6, 2020 | 09:07 PM
Drew's Avatar
No underhood light on Firebirds.
Chances are it's a diagnostic hook up for some long obsolete piece of equipment. The blue wire taped to the harness bundle is another. There's another next to the fuel pump relay. Completely normal to not be connected to anything.
Old Apr 8, 2020 | 03:11 PM
DoctorStoopid's Avatar
Car: 1987 Trans Am
Engine: LG4 305
Is it green? If so, I'm pretty sure it's the connector you use to set the dwell when adjusting a factory computer controlled carb. At least, that's what I use to set it.
Old Apr 8, 2020 | 03:14 PM
RLuzum's Avatar
No, it's just a black connector with a single solid black wire. 350 TPI too, so no carb.
Old Apr 8, 2020 | 04:12 PM
GeneralDisorder's Avatar
That wire bundle goes to the factory ECM and some other stuff like the radiator fans, and some AC stuff. It has the MAF, TPS, and IAC in it.... you could likely trace it back through the bulkhead to the ECM under the passenger side of the dash.
GD
Mason_99
Apr 23, 2015 10:43 PM
majobis
Apr 25, 2012 02:57 PM
BC GTA
May 28, 2009 08:18 PM
Tehsocks
Apr 29, 2009 08:34 PM
buzz12586
Nov 21, 2003 12:09 PM
