hoses
Old May 21, 2020 | 07:28 AM
jpontiac's Avatar
hoses
hello
I bought a pontiac '88 gta.
I have these hoses to put in order
if you have pictures
i think red with yellow
thank you
Old May 21, 2020 | 07:37 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: hoses
Rad (blue to green) coolant jug.
Yellow intake loops to orange or red tbody that exits at purple and goes to heater control valve that splits to heatercore and return line from heatercore.
White on the rad is the heatercore return line. Looks like you are missing the control valve and hard pipe on the frame rail.
Top port orange? on t-body feeds fresh air to pass valve cover.
Old May 21, 2020 | 08:18 AM
jpontiac's Avatar
Re: hoses
ok thank you
Old May 21, 2020 | 08:34 AM
jpontiac's Avatar
Re: hoses
looks like this?
Old May 21, 2020 | 01:23 PM
TTOP350's Avatar
Re: hoses
Yup.
Old Nov 15, 2020 | 05:00 AM
jpontiac's Avatar
Re: hoses
hi
I bought a control valve
but I'm lost in the connections
Old Nov 15, 2020 | 07:28 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Re: hoses
If you don't live in a cold area you can bypass the TB hose. Just cap off #10 and #6.
#9 connects to #2 on the control valve. #4 will connect to the left side heater core inlet located above the pass side valve cover on the firewall.
#3 on the control valve will "T" into the hose that connects to the right side heater core. It runs from the right side outlet to the large (WHITE) fitting on your rad. As TTop says you are missing this hard pipe that would have the "T" connection.
Coolant tank is correct #11 connects to the small fitting on your rad (BLUE).
If you do not want to source the missing hard line from the heater core you can just bypass all of that and just go direct from #9 to the large fitting (White) on the rad. No need for the control valve.
I can't help on the hack job of the wires...ouch!
In this pic my clean air intake (#5) for the VC is capped off. I am using that small K&N filter in it's place. Normally a hose would run from it to a fitting in the VC.
Old Nov 15, 2020 | 09:03 AM
jpontiac's Avatar
Re: hoses
thank you
#10 connects to #6 ?
Old Nov 15, 2020 | 09:05 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: hoses
10 and 6 should have nothing in them if you connect everything else that way. So you can cap them or leave them.
Old Nov 15, 2020 | 09:21 AM
jpontiac's Avatar
Re: hoses
originally how is the connection?
Old Nov 15, 2020 | 09:28 AM
Vader's Avatar
Re: hoses
Originally Posted by jpontiac
hi
but I'm lost in the connections]
You very aptly numbered that last one as "13" since it is very unlucky. That line needs to be connected to "Port 5" on the throttle body, labeled in your other photo. That is the PCV valve air supply and it MUST be metered through the MAF, thus Port 5 should be the air source.
Old Nov 15, 2020 | 09:52 AM
Re: hoses
9 went to 10 with a short and special molded hose. 6 went to 2. That runs coolant through the TB and unless you're cold weather driving it, it's completely unnecessary and just a possible cause of a leak.
Old Nov 15, 2020 | 10:20 AM
jpontiac's Avatar
Re: hoses
2 choices
Old Nov 15, 2020 | 10:31 AM
vinny R's Avatar
Car: 1991 Z28
Re: hoses
2 choices
This would be the proper routing for the way it was done originally. The only issue i see is do yo have a PCV valve on the drivers side VC? It should have a hose that goes into the base in between the runners on the drivers side. Green line in pic should be correct if you have a PCV valve.
Old Nov 15, 2020 | 10:53 AM
jpontiac's Avatar
Re: hoses
driver side
Old Nov 15, 2020 | 12:09 PM
Re: hoses
That appears to be just a breather. I'd recommend putting a pcv valve in place of that.
Old Nov 15, 2020 | 02:39 PM
jpontiac's Avatar
Re: hoses
Old Nov 15, 2020 | 03:44 PM
jpontiac's Avatar
Re: hoses
And the 1
This hose?
Old Nov 16, 2020 | 07:02 AM
vinny R's Avatar
Car: 1991 Z28
Re: hoses
And the 1
This hose?
It Is hard to tell from this photo but it appears to be cut. That does look like the proper vacuum connection for the control valve.
Old Nov 16, 2020 | 08:17 AM
Vader's Avatar
Re: hoses
Agreed. Since this is the first image we've seen of the left side, it would have been tough to guess how that was connected. That now raises concerns about the EGR valve and FPR connections, and the EVAP, and cruise, etc.
Old Nov 16, 2020 | 08:27 AM
Re: hoses
Seeing the scotchlok connector on the TPS wiring is enough to make me concerned over everything.
Old Nov 16, 2020 | 11:44 AM
jpontiac's Avatar
Re: hoses
Old Nov 16, 2020 | 12:01 PM
TTOP350's Avatar
Re: hoses
Need this for the pass frame rail. Goes from rad then "Ts" up to the plastic valve and also back tot the heater core.
Old Nov 16, 2020 | 12:14 PM
jpontiac's Avatar
Re: hoses
Okay. for line 15? I'll see if I have it. I can install a "T"
Old Nov 16, 2020 | 01:22 PM
jpontiac's Avatar
Re: hoses
you have a picture of this connector?
I don't have the same colors
Old Nov 16, 2020 | 07:49 PM
Vader's Avatar
Re: hoses
Ouch. Someone really hacked to get that out of there.
Old Nov 23, 2020 | 06:29 AM
jpontiac's Avatar
Re: hoses
this hose goes here?
Old Jan 16, 2021 | 06:26 AM
jpontiac's Avatar
Re: hoses
hello
on your pontiac this pipe connected like that?
Old Jan 21, 2021 | 07:54 PM
TTOP350's Avatar
Re: hoses
Old Jan 22, 2021 | 02:20 AM
jpontiac's Avatar
Re: hoses
Ok Thank you
I can remove the control valve
illuminati
May 15, 2018 07:56 AM
86birdt/a
Dec 1, 2012 12:47 PM
the_kid
Sep 8, 2009 09:15 PM
johnjm22
Sep 15, 2006 11:53 AM
Crusader
Pacific Northwest Region
Oct 9, 2001 10:00 PM
