is this normal?
Old May 31, 2020 | 11:59 AM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
is this normal?
i pulled the first piston out of my 355 and the locating tabs on the rod bearings are pressed flat.
I just wanted to know if that is normal.
I am attaching some photos. Should I replace these bearings or leave them.
engine has about 1000 miles on it since the full rebuild.
Thanks,
Chris
Old May 31, 2020 | 12:51 PM
Re: is this normal?
No that is not normal.
Looks to me like they spun.
Yes, replace them.
Old May 31, 2020 | 01:09 PM
Chris 84TA's Avatar
Engine: 355
Transmission: WCT5
Re: is this normal?
I should probably check the main bearings too...
man I wanted to get this back together this week
Thanks,
Chris
Old May 31, 2020 | 01:20 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: is this normal?
Thanks,
Chris
What do the crank journals look like?
Old May 31, 2020 | 01:26 PM
Chris 84TA's Avatar
Engine: 355
Transmission: WCT5
Re: is this normal?
crank looks good and rod looks good.
I measured the crank journal and it is 2.08" so I should need a +.020 bearing set, correct?
thanks,
Chris
Old May 31, 2020 | 07:08 PM
NoEmissions84TA's Avatar
Re: is this normal?
thanks,
Chris
Theoretically, yes. but please post pictures. Something is not right here.
Measure the mains bore, the rods bore, and the mains & rods journals.
Old May 31, 2020 | 07:18 PM
Chris 84TA's Avatar
Engine: 355
Transmission: WCT5
Re: is this normal?
i ordered some new bearings. I think the problem was that i didn't get the correct bearings last time. I plasti-guaged them so the thickness was correct. but the diameter is not. there is about a 1/8" gap between the ends of the bearings. I think this contributed to the failure.
thanks,
Chris
Old May 31, 2020 | 07:43 PM
Re: is this normal?
thanks,
Chris
IDK how, but you should consider yourself lucky that this engine ran for even 1 mile.
Old May 31, 2020 | 07:54 PM
Re: is this normal?
That's basically ... impossible. You'd have to have a small-journal 327 crank or rods for some other kind of motor for that to happen. Or of course the wrong bearings.
They're supposed to be a "crush" fit into the cap. That's what retains them. Without that, you get ... what you got.
2,100" is the nominal dia for a 350 rod journal, so yes, +.020" would be correct. 2.225" is the inner dia of the rod. Measure it to be sure. Clevite bearing part # should have 663 in it.
Old May 31, 2020 | 08:21 PM
Re: is this normal?
Old May 31, 2020 | 10:42 PM
Chris 84TA's Avatar
Engine: 355
Transmission: WCT5
Re: is this normal?
I think they sent me the wrong bearings. It was my first time assembling an engine by myself, so I didn't notice.
Old May 31, 2020 | 10:43 PM
Chris 84TA's Avatar
Engine: 355
Transmission: WCT5
Re: is this normal?
Old Jun 1, 2020 | 02:04 AM
BadSS's Avatar
Re: is this normal?
It's hard to believe the oil pressure wasn't going all over the place and it ran for 1,000 miles without marring up some rod journals on the crank or the bearing surface of the rods. I think if I were you, I would take the crank and rods to a decent machine shop and get them to measure everything - it would be worth it for peace of mind if I were you.
I saw the other thread you started about having issues with the lifter plungers and a bent push rod. With the statement of assembling your first engine, it makes me wonder if you tightened the rocker arms until you couldn't spin the pushrod then went a 1/4 turn. I've seen folks do this before, but usually it results in most of the pushrods bent as they typically tighten more than a 1/4 turn on their first build. Zero lash on a hydraulic is "zero" without the plunger being depressed - the pushrods will spin freely but have no up and down movement. Just wanted to make sure you were good on this before reassembly.
Old Jun 1, 2020 | 06:19 AM
Re: is this normal?
Yup, wrong bearings. What was the part #? How are the mains?
Old Jun 1, 2020 | 07:53 AM
Chris 84TA's Avatar
Engine: 355
Transmission: WCT5
Re: is this normal?
i will be checking the mains later today.
these are cb745hd .010
I find references to them being made for chevy sb and ford ...
this motor ran good and never knocked, but it was some oil...
I am re-ringing it too. I have an old mechanic that lives across the street. I showed him, and he said I was really lucky to not have any damage
thanks,
Chris
Old Jun 1, 2020 | 05:19 PM
Re: is this normal?
No idea what that's for.
No idea how ANYBODY can look up bearings for a Chevy 350 and come up with the wrong thing. That person needs to seek a new career, perhaps in the sanitation engineering or fossa excavation industries.
Old Jun 1, 2020 | 05:42 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Re: is this normal?
I'd say ^^^^that's your problem.
Old Jun 1, 2020 | 06:38 PM
Re: is this normal?
SMALL Journal SBC .010" under
You better check the main bearings. They could also be for the small journal crank.
Just so you know, small journal cranks were used from 1955-1968.
Old Jun 1, 2020 | 08:10 PM
Chris 84TA's Avatar
Engine: 355
Transmission: WCT5
Re: is this normal?
I am going to check them, but I am pretty sure the mains were correct.
Thanks,
Chris
Old Jun 4, 2020 | 02:33 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: is this normal?
You need to inspect (measure) the rod bore for wear as well, yes?
Old Jun 4, 2020 | 08:34 PM
Re: is this normal?
Without actually seeing the rod bores, and with the bearing inserts spinning in them for 1000 miles, I would think that there would be damage.
I can't believe the inserts were not spit out.
zupta82
May 3, 2020 07:49 PM
Tootie Pang
Oct 20, 2019 09:20 PM
R4][N_M4l{3R
Jun 1, 2006 04:36 PM
sellmanb
Oct 18, 2004 11:21 PM
