4th-Gen Starters
Old Aug 8, 2020 | 03:00 PM
Moonlight137's Avatar
Car: 1992 RS
Engine: L03 / MSD / 2½" "hacksaw" catback
Transmission: 4L60
4th-Gen Starters
Hi, I have a 92 RS 305, and I bet one day I'll need a new starter.
When that day comes, should I get a Remy 96207 starter (for 95-97 F-bodies, according to rockauto.com), or should I get the 96220 (for 98-01)? I can't find any info on why they use two different starters. Which is better?
Or is there an even better factory-type replacement? I see others on Rock Auto that say they also fit 2002. Not looking seriously at aftermarket upgrades yet.
Thanks for any advice!
Old Aug 8, 2020 | 06:37 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
Re: 4th-Gen Starters
You can use a LT1 style starter on the L98, its a nice stock upgrade
Old Aug 8, 2020 | 06:47 PM
Black 84 Z's Avatar
Car: 1984 Z28
Engine: 350ci
Axle/Gears: 3.73 12 bolt
They switched to LS1 engines in 1998 thus the different starter. Agree with the above on changing to an LT1 starter. Its smaller and lighter yet stronger and uses fewer volts.
Old Aug 8, 2020 | 09:28 PM
Car: 1992 RS
Transmission: 4L60
Thanks for the replies! Is there any reason the 98 LS1 might work better than the 97?
Old Aug 8, 2020 | 09:29 PM
GeneralDisorder's Avatar
Originally Posted by Moonlight137
Thanks for the replies! Is there any reason the 98 LS1 might work better with my 305?
LS starter is not compatible.
Old Aug 9, 2020 | 10:33 AM
Right: it's one of those "exactly the same except completely different" kind of things.
Won't bolt up.
The LT1 however is a traditional SBC in most respects, including the starter. That one will work.
Old Aug 9, 2020 | 11:01 AM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
is the lt1 starter small enough to work with headers? i need to run a mini with my headers.
Old Aug 9, 2020 | 11:17 AM
Depends on the headers. It will depend on how well-designed they are. Which some, are EXCELLENT; some, I wouldn't wish on my worst enemy.
Does a hamburger taste good?
The giant boat-anchor OE one works with most. Anything smaller surely can't be much worse. Would probably improve the odds even with the crappiest of all teh crappy headers there have ever been.
Old Aug 11, 2020 | 10:48 AM
SilverChicken's Avatar
Car: 1986 Pontiac Firebird
Engine: 383 SBC
Axle/Gears: Hawks 8.8 with 4.10’s
Get the bolts for the LT1 starter too. They’re a different length from the giganto original 305 starter.
Old Aug 11, 2020 | 02:29 PM
https://www.meziere.com/Products/Sta...153-tooth.aspx
Works great with my Dyno Don headers and y-pipe.
GD
Old Aug 11, 2020 | 06:53 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
I have researched this a bit in anticipation of mine shitting the bed and the LT1 Remy is a bargain to me, the C4 starter from 89 up is nice too but may not bolt up as easily IMO( might not have enough wire and the LT1 looks more like factory but smaller) and both may require different bolts for the starter. Do a search and you will find a ton of info on this, it’s almost overwhelming.
birdie_76
Sep 22, 2013 01:48 AM
jmilano89
Jan 31, 2011 03:04 AM
white04
Jan 8, 2011 02:42 AM
92_T-5
South Central Region
Oct 28, 2009 03:42 AM
TurbomanKnight
Jan 23, 2007 07:20 PM
