Cranks but doesn't turn over
Old Nov 21, 2020 | 03:43 PM
scarr001's Avatar
Car: 92 camaro rs anniversary edition
Engine: v8 5.0 Tbi
Hi
i have a 1992 v8 Camaro RS. Its been sitting two years or so and I just put a new battery in, added some fresh gas (had about 1/4 tank in it) and it cranks but won't turn over. Don't know how long I should keep trying to see if it catches, I hear the fuel pump...have never primed it by putting gas directly into the TBI. Any ideas? Thanks
Old Nov 21, 2020 | 05:32 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Cranks but doesn't turn over
injectors may be stuck-pour a little gas down the TBIs and crank it-if it runs for a moment,probably stuck injectors.If the poured gas has no effect,check for spark.
Old Nov 21, 2020 | 08:03 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Cranking is turning over....
Old Nov 22, 2020 | 02:52 PM
scarr001's Avatar
Engine: v8 5.0 Tbi
Got it to start, REALLY rough while idling, some backfire (not much) am sure it's the old gas? Suggestions?
thanks
Sharon
Old Nov 22, 2020 | 06:09 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Are both injectors spraying? also you should remove and reinstall all the fuses in the fuse panel to reestablish good contact.
LastKnownOne
Feb 7, 2011 08:34 PM
jll87TA
Dec 17, 2010 01:01 PM
lukeylouk
Oct 5, 2008 01:22 AM
streetassasin
Jul 10, 2006 08:42 AM
T3am Z28
Feb 2, 2003 07:02 PM
