Help! My IAC valve wires might be crossed.
Old Jan 21, 2021 | 10:56 PM
GBousley's Avatar
Car: 1992 Firebird base
Engine: 305 TBI
Transmission: 700r4 / 4l60
Axle/Gears: stock
So, the harness / clip on my IAC wiring harness dry-rotted and snapped and now I have no way of knowing which way the harness plugs into the IAC valve (there's no clear indication which way is up). It's a 2 over 2 clip, with 2 green and 2 blue wires (each with white and black stripes). The bird is a 1992 305, anyone know the correct coloring position of the wires and can explain which position they plug in? I have a new harness I need to wire in..
Thanks!
Old Jan 21, 2021 | 11:00 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Help! My IAC valve wires might be crossed.
https://www.thirdgen.org/forums/tpi/...t-iac-use.html
Old Jan 21, 2021 | 11:02 PM
Engine: Lb9
Transmission: M20
Old Jan 21, 2021 | 11:04 PM
Engine: Lb9
Transmission: M20
If the plastic is broken best not to splice just unpin the weather pack connector.
Old Jan 21, 2021 | 11:37 PM
GBousley's Avatar
Engine: 305 TBI
Axle/Gears: stock
I found that diagram, but it's hard to follow. Since the wiring positions are stacked and the diagram is flat. Also, not sure what you mean by unpinning the weather pack connector.
Old Jan 22, 2021 | 12:01 AM
Engine: Lb9
Transmission: M20
Look at the letters on the connector. You can release the connector by inserting a release too. Retention the connector ears and install in the new connector housing.
Old Jan 22, 2021 | 12:04 AM
Engine: Lb9
Transmission: M20
https://www.ebay.com/itm/K4-Terminal...EAAOSw339eijPX
Old Jan 22, 2021 | 11:02 AM
GBousley's Avatar
Engine: 305 TBI
Axle/Gears: stock
Thanks a BUNCH! Got it figured out. AND replacing the IAC valve fixed my low idle. It would almost die when I put it in gear from park. Idling perfect now and starts right up into a smooth idle.
crimsoncomedian
Mar 30, 2012 12:23 AM
kowboy59
Mar 20, 2008 03:53 PM
Tbi-MAX
Nov 19, 2007 02:39 PM
jjlabinski
Jul 3, 2006 05:24 PM
9D1BURD
May 7, 2002 12:28 PM
