90-92 Computer, 7 pin Ignition control module?
Old Feb 24, 2021 | 12:53 AM
JeepingDrake's Avatar
as I am digging into this car and the gremlins, when I look up modules or Dizzy's for this rig, I'm getting the distributor that has the "flat" side with two plugs, not the typical HEI large cap, that I replaced on my car. As I am new to these motors, and I know the ECM controls timing, now I'm paranoid that I was throwing 1987 parts at this thing, however I did replace the stock, or what appeared to be the stock A/C Delco distributor with a Chevy plug and play DUI, maybe I'm over thing this. P
ics are what I have on what is at least a 90-92 ECM
Old Feb 24, 2021 | 08:23 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 90-92 Computer, 7 pin Ignition control module?
Yes, the '90 - '92 f-body TPI set ups used the small cap distributor with the remote coil. You can ask for '90 - '91 y-body (Corvette) distributor parts as they stayed with the big cap distributors.
RBob.
Old Feb 24, 2021 | 09:09 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
You can use the one you bought (the fat cap HEI). I swapped to one on my '90 GTA from the small cap to reduce the clutter. The wires leading to the distributor from the ECM need to be inverted, and you'll need a female/male connector half from a fat cap setup coming from the ECM (which will be the piece you invert) to attach to the large cap's male connector coming from your distributor...
- Rob
Last edited by Street Lethal; Feb 24, 2021 at 09:26 AM. Reason: Was more specific...
Old Feb 24, 2021 | 09:26 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.ebay.com/itm/Chevy-Large...wAAOSwEZdaOc2s
or the vette large cap hei was 85-91
Old Feb 24, 2021 | 01:19 PM
So does it really matter if there is a large cap in the car vs small cap? Am I missing something here in my ignorance? The car ran fine until recently. waiting for my data cable from Moats.
Old Feb 24, 2021 | 03:15 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
As long as the big cap distributor clears the firewall, no, it doesn't matter which one you use. If the wiring is for a big cap, and it looks like it is. Then stay with it.
I have no idea why GM changed between large and small cap distributors (maybe inventory on hand?). I've run both in various vehicles. Didn't matter to me as long as it cleared the firewall (big cap won't on 1st gen f-body cars, but does on the El Camino).
RBob.
Old Feb 24, 2021 | 06:16 PM
ULTM8Z's Avatar
Doesn't he need to run the ANHT/AXCN Vette spark latency tables if he's running the big cap distributor?
The tables are significantly different between AXCN/ANHT and the Camaro AUJP.
My recent experience with modules vs latency tables shows you can get very different results in the spark timing being commanded by the ECM vs what comes out at the distributor.
Old Feb 24, 2021 | 11:17 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
And what is the latency of an aftermarket ICM?
RBob.
Old Feb 25, 2021 | 08:45 AM
ULTM8Z's Avatar
You'd have to run that test in that other thread.
https://www.thirdgen.org/forums/diy-...ncy-table.html
Which is why it's probably better to get a Delco original since we know those work with the factory latency tables.
BB72Camaro
Jan 27, 2021 09:53 PM
AssaulT/A
Alternative Port EFI Intakes
43
Apr 16, 2018 06:31 PM
Sttn89
Mar 4, 2012 03:06 PM
wake77
Feb 14, 2006 03:55 PM
rwelch
Jan 6, 2001 10:54 AM
