Vortec heads AC and Alternator bracket ?
Old Jul 16, 2021 | 11:29 AM
Out-Cast's Avatar
Car: 1987 IROC z
Transmission: 700R
Axle/Gears: POSI 3:27s
Engine is a 1987 350 TPI. Running Vortec heads
EDIT: along with the First Performance TPI system.
I have a question.
For those running Vortec heads in your 350 TPI what did you do for the AC compressor bracket ?
The bolt holes on the factory bracket don’t line up.
Also the alternator bracket doesn’t line up when bolted to the plenum ??
EDIT: do I need the brackets from
A specific vehicle that runs Vortec heads from the factory ?
Old Jul 16, 2021 | 11:44 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Re: Vortec heads AC and Alternator bracket ?
Are you talking about the horseshoe looking bracket that bolts to the front 2 intake bolts?
Old Jul 17, 2021 | 07:55 AM
Out-Cast's Avatar
Car: 1987 IROC z
Transmission: 700R
Spoiler
Yes where the alternator bolts to the intake.
I forgot to mention I’m running a First Performance intake
I’ve got some responses on the FB groups and others have had the same problem.
looks like I have to fabricate a bracket.
Old Jul 21, 2021 | 12:35 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
So the issue is with the intake, and not the heads?
Old Jul 21, 2021 | 01:07 PM
Out-Cast's Avatar
Car: 1987 IROC z
Transmission: 700R
Ya since the intake is not OEM the mounting location for the alternator bracket has no spot to be secured.
I just hacked up the OEM bracket and took it to my buddy to weld.
Going to be a PITA to keep cutting and welding until it’s right
Old Jul 21, 2021 | 02:59 PM
Out-Cast's Avatar
Car: 1987 IROC z
Transmission: 700R
Not pretty but I will some thing nicer once I get the car running. Yes I’ll be putting a spacer behind the bracket.
I just need the alternator secure and straight for now.
Old Jul 22, 2021 | 04:03 PM
That doesn't look like a real good spot for a brace... a very small bolt, secured into very little material.
I think you'd do better by making something that would go down to the intake bolts.
Old Jul 22, 2021 | 04:20 PM
Out-Cast's Avatar
Car: 1987 IROC z
Transmission: 700R
As I said above it’s temporary until I get the car running and order an alternator lowering bracket.
And the Alternator is actually real secure without the bolt even in place.
morepowerjoe
Feb 3, 2015 03:01 PM
1badnhra
Mar 31, 2011 02:56 PM
The Chad
Oct 15, 2007 05:53 PM
PhantomFE3
Jul 12, 2006 12:50 PM
