Starter Engagement Question
Old Aug 5, 2021 | 05:54 AM
cwb90's Avatar
I have a completely stock 88 Iroc 5.7 TPI 700r car. My starter will spin the engine fine but every now and then it will just grind. If I turn the engine over by hand just a little then the starter engages fine. So yesterday I took the inspection cover and starter off and inspected all the teeth on the flexplate. They were good so I decided to get a new starter. After reading recommendations on this site I decided to get a mini starter from a 96 corvette like others have recommended. I put the starter on and when I was checking clearance I found that the starter gear only engages with half the flexplate teeth (only goes in half way). I decided to try and turn it over and it just ground also. My question is did I just get the wrong starter or am I missing something. Thanks and any help is appreciated.
Old Aug 5, 2021 | 06:17 AM
wlink14's Avatar
Car: '87 TA
Engine: 6.0LS
Transmission: 4L80e, 3000 stall
Axle/Gears: DIY 9 inch, 3.00 gear
Re: Starter Engagement Question
Battery at full voltage? Good electrical connections? You say completely stock but is the flywheel original? It is a possibility to get a bad part even though it is brand new. There aren't too many variables, just start eliminating some and work forward from there. Keep us updated!
Old Aug 5, 2021 | 07:39 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I don't believe the starter gear is intended to fully mate with the flywheel. I "think" it only engages half way by design.
Old Aug 5, 2021 | 07:59 AM
cwb90's Avatar
If that's the case maybe it just needs shimmed. Can anyone else verify this?
Old Aug 5, 2021 | 09:04 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Every mini starter i've ever used only goes about half way into the teeth of the flexplate.
Some causes for a grinding starter can be,...cracked flexplate, wrong starter bolts, incorrect clearance/shim, or worse yet,...the dreaded cracked outer starter bolt hole in the block.
Old Aug 5, 2021 | 09:27 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Shimming will only affect your pitch clearance. The amount that the starter gear extends is fixed.
Old Aug 6, 2021 | 06:25 AM
cwb90's Avatar
Replaced the 96 Corvette starter last night with a PowerMaster 9100 from Summit and everything is good! The starter gear extends the correct distance to flexplate and I did not need to shim. Perfect right out of the box and cheaper than the corvette starter. I would highly recommend this to others doing the upgrade. Bonus of the mini starter is that I did not have to remove any of the exhaust pipes.
Also, thanks to each of you for your replies and help. It's greatly appreciated!
Old Aug 6, 2021 | 06:53 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I too just switched to powermasters hi tq LS starter, and I am very impressed.
Old Aug 6, 2021 | 04:44 PM
BOOT77's Avatar
Got a few Powermaster SBC mini starters myself
Old Aug 8, 2021 | 11:30 AM
Vader's Avatar
One nice feature of their 9000-series starters is the full-contact flat surface at the top of the mounting flange. That can help resolve issues when bolting a starter up to a block with "the problem" in the starter mounting pad area.
sunbound
Jun 12, 2020 10:23 AM
89WS-6
Nov 25, 2002 02:52 AM
